not sure how many have a scangauge II but my issues are that the boost reading is at 0.0 or when i get on thottle it will go to negative numbers up too 0.9. also the display numbers change very slowly, truck runs fine, thanks
Yes it does read boost for our trucks. We have to program it for altitude. It has been long enough ago that I don't remember how to off the top of my head. I would have to do more research. It might be faster to get in touch with Linear Logic and get expert help.
Set the Manifold Pressure Method: If your vehicle is equipped with a turbocharger or supercharger, you may want your vehicle’s manifold
pressure calculated and reported as Boost (BST) as opposed to Manifold Absolute Pressure (MAP). This parameter allows you choose the method ScanGauge should use to calculate and display manifold pressure.
