why such a big diff in boost?
Old Apr 15, 2012 | 10:03 PM
STROKED-OUT's Avatar
STROKED-OUT
Alright guys don't eat me alive here but I do not understand this. My buddy that I shoot with has a 24 valve cummins with 90 over injectors and up grade Turbo (don't know which one) and is Smarty tuned. He tells me he sees 72 psi of boost HOW IN THE WORLD IS THERE SUCH A BIG DIFFERENCE? I know my truck is not set up for anything like that kind of boost such as injectors, Turbo, head studs, and other supporting mods but the beat boost I have seen was like 28 psi and i was really giving it HELL....but my point is even if i did have the upgraded parts I still do not think I would ever see that kind of boost. I know some one will say that boost doesn't mean more horse power and stuff like that, but what does it mean I have not been able to full comprehend why more boost is better? But can someone please explain why the cummins motors seem to produce more boost than ours do? Thanks everyone.
Old Apr 16, 2012 | 01:25 AM
CSIPSD's Avatar
CSIPSD
Your buddy is FOS... He might be making 45-50# of boost, but not 70+...
Throw a set of hybirds and a turbo at yours and you can make 40+ psi.
Old Apr 16, 2012 | 05:21 AM
Tugly's Avatar
Tugly
More boost in means you can add more fuel and it will burn instead of smoke. It brings up the compression stroke pressure, which means more heat to ignite the fuel better.
28 PSI max? That's about where I'm at, the boost jumps to 27-28 and hangs there until I crawl back out of the throttle. I'm satisfied with that because it's cheaper than the alternative.
72 PSI? Tell him the boost sensor is not supposed to be on the exhaust side, it's probably melted and reading wrong. Other than that, I'd be looking for solid proof before I bought into any boost gauge that said that. The intercooler would have real issues trying to cool down 72 PSI enough to not melt plastic unter the hood. Remember, the exhaust out has to pump that up - and that means the exhaust side could be sneaking up on 80-85 PSI, depending on the turbo design. EGTs would warm right up with a buried foot. If somebody were able to coax that much boost out of a turbo, they would know precisely how they did it - because it wasn't an accident and it costs a bundle. I'd ask him how he did it, and his reaction will yield some impressive hardware, or be unrecognizable techno-babble, or he'll just say "I dunno, my mechanic did it".
I envision a scenario where somebody put a different face in the boost gauge, or he has an air compressor on the surpentine belt and it's connected to the biggest boost gauge he could find.
Old Apr 16, 2012 | 05:48 AM
CSIPSD's Avatar
CSIPSD
Originally Posted by Tugly
More boost in means you can add more fuel and it will burn instead of smoke It brings up the compression stroke pressure, which means more heat to ignite the fuel better.
You cant make more boost without more fuel... fuel makes drive pressure which makes boost...
You cant make more boost then add more fuel, its the other way around.
Old Apr 16, 2012 | 06:29 AM
Tugly's Avatar
Tugly
I'll rephrase.
If your vehicle has a capacity for more boost, you can have bigger sticks and add more fuel to the tune without getting unburned fuel and smoke.
Old Apr 17, 2012 | 05:02 PM
STROKED-OUT
This is coming from a good buddy of mine that I shoot archery professional with....he is a very knowledgeable guy and I respect his word. But when I first heard it I was in disbelief. So what your saying is that if he had the boost gauge hooked up on the exhaust side that then he could be seeing these boost numbers? And if it is hooked up on the exhaust side does that mean it is wrong?.......Thanks guys I just want to get to the bottom of all this cummins is better than powerstroke thing......ALL MY BUDDYS LIVE AND DIE CUMMINS........my uncle and I are the only smart ones haha..
Old Apr 17, 2012 | 05:26 PM
Crewcab Turbo's Avatar
Crewcab Turbo
72 psi boost? I don't know butt, do they make a boost gage that goes that high?
Old Apr 17, 2012 | 05:58 PM
STROKED-OUT
That was another one of my questions haha
Old Apr 17, 2012 | 06:17 PM
meierw1's Avatar
meierw1
Pretty sure they make a boost gauge that goes to 100 psi. They may have a bigger one but I'm unsure
Old Apr 17, 2012 | 08:11 PM
CSIPSD's Avatar
CSIPSD
Exhaust side of the turbo is called Exhaust Back Pressure or Drive pressure. It is NOT boost, but the worker that creates boost.
Dont care how much you trust your buddy, if he says he is making 72# boost with only 90hp injectors then he is FOS. Not enough fuel there to make those boost numbers, short of maybe a set of compounds.
Yes... I run 60psi boost gauges in my truck, I have 100 psi one's as well. I have 180psi air pressure gauges that with a slight tweak in the programing would react as a boost gauge as well.
Old Apr 18, 2012 | 07:45 AM
rufushusky's Avatar
rufushusky
Bingo and 72 psi is a lot of drive pressure for an ISB, so he is working that turbo pretty hard. With 90hp injectors and a turbo in the 58-64mm range he might be making 35-45 psi...so he is looking at almost 2:1 drive to boost ratio, sounds like he needs less fuel or a bigger exhaust housing. At 72 psi of boost/intake manifold pressure without studs he would send his head into orbit.
Even with a set of compounds on that truck there is no way he could make that much boost off 90 horse injectors...please tell me he is not running the stock POS dodge lift pump either...cause if so he is most certainly pulling fuel pressure below 10 psi and his VP44 is on borrowed time.
Old Apr 18, 2012 | 11:47 AM
STROKED-OUT
Man Good lookin gauge set up..........Eventually I would like to move mine up on the pillar, currently they are mounted on the dash behind steering wheel can be hard to see sometimes......but back on subject.......So basically from what I understand is with his truck only having 90 over injectors there is no possible way he could get 72 psi of boost? But it is accomplish-able with bigger up graded parts?
Old Apr 18, 2012 | 11:59 AM
rufushusky's Avatar
rufushusky
On a PSD or CTD? As far the 24V Cummins (assuming a VP44) a hotrod VP44, 150-250hp injectors, bigger lift pump, fire rings, studs and a s364/s480 then he could be making 70 psi of boost with reasonable drive pressures but it would be pretty smoky at low boost and slow to spool for a set of compounds.
sudsmcduff
Jan 11, 2015 09:57 PM
Tugly
Nov 16, 2012 09:59 PM
maple sapper
Oct 3, 2012 08:54 AM
Tugly
46
Sep 5, 2012 01:09 PM
PSlover
Oct 29, 2004 11:52 AM
