Will keeping the doghouse clean cut down on oil getting to the IC without having to MOD? In other words, if I can clean the doghouse every 10k or so, is the mod still beneficial?
I personally feel you will benefit from keeping the doghouse cleaned out if you do it any of the 4 ways. Stock, exhaust, catch can or open to air. I think if you clean it out every 10k on a truck with less than 75k in stock. Cleaned every 5k with less than 150k going to stock. This mod helps more so on thruck with high mileage or running more than stock boost.
Either way CLEAN the doghouse!!
Originally Posted by Cell's
Not to start a debate over this mod or not .....but....
someone I know said that the vapor from the crankcase is routed back into the intake to give the turbo intake bearing lubrication .
What are your thoughts about this ??
LMAO Sorry but that is so far off base I can't help but to laugh. If you follow that line of thinking oil from the compressor wheel would get to the bearing...And how since there is a seal between the compressor wheel and bearing. If that was true oil from the oil bushing/ bearing would be able to flow the other way too. And that is NOT suppose to happen. So the answer is NO that is not true.
My dog house is RVT'ed to the valve cover. I dont remove it for anything. I can not imagine removing it at every oil change for any reason what so ever.
Maybe I should add a doghouse gauge like Joe. That way I can keep an eye on it... Sorry joe, I couldn't pass it up.
I still don't quite understand the real issue. Is it just to keep oil from settling in the IC? And will oil in the IC cause failure or reduced efficiency other than possible issues with stock boots? Sorry I'm going all the way back to basics here.
Always with the gauge jokes... LOL
The issue is the oil vapors over time coat the inside of the intercooler, reducing its efficiency. The boots issue can be solved with quality boots over a CCV mod, but nothing can fix those efficiency issues.
I just run mine to vent outside. Its easy, fool proof and causes NO issues.
Joe I agree there is no way that is happening everytime you change oil so hence ccv modd. But cleaning it would help. I am NOT saying clean it every 10k or 5k but I am guessing that if you did you would get next to nothing going back into intake. I knew you had alot of gauges but I didn't know you had a gauge to measure crank case pressure..Cool
I didn't take a good look inside the doghouse while I had mine off, but isn't it just a wad of steel wool-type stuff? I'm thinking its purpose is to give oil vapors somewhere to condense and drip back down into the engine. It's hard to imagine it getting "dirty" or "clogged"; seems like it would be all coated with oil again in the first 20 minutes you ran the motor after you cleaned it.
Mine is turned around, and routed to atmosphere. The hose from it goes uphill, over the brake booster, before going back down and exiting by the frame. I think the uphill run would give vapors even more opportunity to condense and drain back down. I figure that as long as I keep seeing healthy puffs of smoke coming out of the end of my CCV hose, it's not clogged.
You are correct with your entire post...
Removing it and cleaning it, is like changing your HPO... Does nothing, but cost you time, and money.
I have a question: If it's loaded up with old and sooty oil, wouldn't everything just get sucked through? If it's clean with fresh oil, wouldn't it pass the air and do a better job of dripping the oil back down into the VC? I look at the design and it looks like that was the original intent.
If the truck is never up to operating temps that might be an issue, but its like cleaning out the inside of the valve cover... The minute you start the truck, its covered with oil again.
Its not a filter, just a cooling area.
Again, for a bunch of guys who talk about K.I.S.S all the time it just kills me when you worry about thing that are so simple.
