CCV Mod Re-Visited
Old Sep 28, 2012 | 03:42 PM
  #31
Tim Hodgson's Avatar
Tim Hodgson
Current moves upstream behind obstacles (i.e., an "eddy"). So diagram "A" will actually push current into the tube opening (think hair flying forward on those in the front seat of a convertible with top down). (Or for more fun, watch a whitewater kayaker catching an eddy and immediately turning upstream to the safety of the backside of a rock in an otherwise ripping rapid.)
So, diagram "B" will not create the eddy at the opening of the tube. But it will create it below the opening of the tube where it wouldn't push current into the tube opening.
I don't know if this mod is a good idea or not, and I have to decide what to do soon before I re-install the dog house on my valve cover, but between the two "B" seems better.
I think the dog has it right.
(But I really am new to all this.)
Old Sep 28, 2012 | 03:46 PM
  #32
timmyboy76's Avatar
timmyboy76
Hodgson, in comparison to your "eddy" theory. The "bilge" design thats incorporated into seadoos mainly..(i repair them), is a picture of type "A". The bilge works by vacuum. There 2-white post, atop the jetstream in the pump assy. With water passing over them, it creates the vacuum, resulting in, if any, water to be expelled out of the hull, and into the "stream".
Old Sep 28, 2012 | 03:57 PM
  #33
Tim Hodgson
Tim, I only spoke from my personal experience. I apologize if I was wrong or if my experience was limited. As I said, I am new to all of this ...
Old Sep 28, 2012 | 04:16 PM
  #34
timmyboy76's Avatar
timmyboy76
Hey Tim, no need to apologize, man. We agree to disagree. I too, am learning as well, most of this, is "chinese' to me anyway, but how you interpreted/responded, made me think of how that "system" works, and somewhat in a similar fashion. I still cant grasp the fact that the air coming in thru the filter from the turbo, is not pressurizing the crankcase, considering, the ccv spigot is shoveled and directed toward the filter?
Old Sep 28, 2012 | 04:24 PM
  #35
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Tim, there is no presure in the intake tube. The turbo is pulling a vacuum to pull air through the filter. The opening of the CCV is before the filter, so I'm sure there will be a small vacuum in that tube.
Old Sep 28, 2012 | 04:25 PM
  #36
Tugly's Avatar
Tugly
With respect and just trying to be helpful,
  • Water vs. air
  • Very high pressure differential vs. almost no differential
  • Moderate-to-High velocity vs. screaming velocity
I don't know where to start on this... the combination of all the variables above grabs the example by the shoulder and gives it a good shake. Suffice to say that a 90 HP water pump is going to have some differences in venturi-effect intensity from a diesel's post-turbo exhaust.
As for "A" vs. "B", I would theorize that "B" should be flush with the exhaust pipe wall to reduce the chance of eddies from the tube stickin' in there. I would also think that you would want to smooth the edges inside the tube so a sharp edge won't "catch" some of the flow.
I wouldn't even try this unless I had a test configuration that could prove if it works or not. It's a whol' lotta misery if it ain't right.
  #37
1954oldred's Avatar
1954oldred
Vent it to the atmosphere and be done with it...what is the big dilemma ?
Mine have been this way for years and thousands of miles with no concern and no harm to sea turtles or unicorns.
Old Sep 28, 2012 | 04:29 PM
  #38
trekbasso's Avatar
trekbasso
I will agree with BDK, because it works. I put a larger catch can, like on "Guzzles" mounted behind the drivers wheel well. Routed the hoses through it. Creates enough distance and a place for oil vapors to condense, back into the intake. Very very little liquid gets through.
Drain maybe once a month, no big deal. No more residue around the intercooler.
Pretty darn simple. About 30 bucks. Bought everything at hardware store.
Old Sep 28, 2012 | 05:39 PM
  #39
Fat Diesel's Avatar
Fat Diesel
Originally Posted by 1fixitman
The OEM CCV goes to the inlet of the turbo which is usually at a slight vacuum. If you removed all your cac pipes and intercooler then you would know that all of that stuff was completely coated in oil that came from the CCV. Route the CCV to atmosphere. DO NOT HOOK UP TO YOUR EXHAUST IN ANY WAY to the CCV. The CCV needs to be able to breathe. Your exhaust is at a pressure. You will melt the line that goes to your CCV and blow your rear main seal or front seal if you attempt this. Not a good idea in any way.
Dwayne
Wow that happend to you? Mine has had ZERO problems in well over 150,000 miles routed to the exhaust..
Most people who bad mouth this mod have not actually done it. They just parrot it like it is true.
Old Sep 28, 2012 | 05:46 PM
  #40
Bonanza35's Avatar
Bonanza35
As Andy says. I have read on here where they have put them in the down pipe with the check valve installed and it work prefect also.
Chet
Old Sep 28, 2012 | 07:20 PM
  #41
BadDogKuzz's Avatar
BadDogKuzz
Well Bill you seem to have your mind made up to do your ccv mod to exhaust. And for the life of me I couldn't remember exactly how I did it the last time I had installed a ccv to exhaust but I did remember that I had used a Vibrant kit. Vibrant makes some nice stuff.
Vibrant Performance E-VAC Scavenger kits are dyno proven to pull up to 3" of vacuum from race motors, improving horsepower and reducing crankcase pressure.
Vibrant Performance ::.
Here is a photo of the correct way to install.
Stainless Steel E-VAC Scavenger kit
Old Sep 28, 2012 | 07:25 PM
  #42
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
those are good links kuzz.....thank you....i like the stainless one....
Old Sep 28, 2012 | 08:21 PM
  #43
BadDogKuzz's Avatar
BadDogKuzz
I thought you would like the SS, the last ones I installed was mild steel. Rusted up after about 6 mths and I said I should have bought the SS.
Now they say you can get 3" of vacuum from race motors which turns high rpms and higher velocity more than a turbo diesel will ever turn. Now if you are running a 4" exhaust I am sure you will still be able to get a fair amount of vacuum to do the job. But honestly if you are running a 5" exhaust it might not have enough on the velocity to not be much help. But would still better than just venting it to atmosphere.
The last ccv to exhaust I did the I installed them 3" past the collector on v8 gasser with headers. I have also installed them into the collector on headers with no ill effects. Now I might be new to turbo diesels so please take that into consideration when I say I think you would be fine putting it about 36" back from the turbo. I wouldn't think you really need to go to the rear with it. Besides with lower velocities you might be better off staying towards the front. Actually it is hard to say when running a low rpm engine with a huge 4" or 5" exhaust.
Old Sep 29, 2012 | 11:02 PM
  #44
cutlass's Avatar
cutlass
Subscribing.....
Old Sep 30, 2012 | 10:19 AM
  #45
Ponyboychris's Avatar
Ponyboychris
Hippies and tree huggers be damned... Mine is routed to atmosphere with a catch can. Never had an issue.
