I think you have to first disconnect the electrical connector. Then reach behind and grasp the switch and push in towards the dash and turn. The spring tension is pretty hard so reinstalling will be alittle tough. Now to remove the key cylinder ign s/w housing, you have to insert a paper clip into the small hole and turn the it with the key in the cylinder.
