2004 6.0 Automatic sometimes will not go into gear
I'm having similar trouble with my shifter being stuck in Park. When it started happening a few months ago I opened up the Brake Pedal Switch and cleaned it up with a wire brush and contact cleaner. There was some corrosion present. Looked like new going back in. It seemed to help for a while, but now its doing it again and the contacts in the switch are still squeaky clean. I bought a new Brake Pedal Switch but once I install it, I can't return it. My shifter is pretty sloppy - presumably from the previous owner cranking on it trying to get it in gear. Can anyone tell me if the solenoid in the column is prone to failing, when its been cranked on? Any way to check it? If not, I'll fire in this new switch and hope that does it. Thanks
2003 6.0 CC 4x4
2003 6.0 CC 4x4
Thanks for the reply Mark. I'd popped apart the column before seeing your reply. Wasn't too difficult, and needed a good cleaning in there anyway. When I didn't find anything loose, i decided to just plug in the new brake pedal switch and it seemed to fix the problem. I'll check into the tube/shaft/bushings as you suggest to tighten up the shifter before it fails, when I have a chance.
THx again.
THx again.
