Gear selector lockout
Old Jul 20, 2007 | 05:37 PM
TOW4H2O's Avatar
TOW4H2O
I have a 2004 6.0 TD that in order to get the shifter out of park I need to really stand on the brake pedal. Then just realized that the cruise control won't disengage unless the brake pedal is pushed down hard. Not just the tap it took before. Are they related? Is it the strange switch up under the dash attached to the brake pedal arm?
Thanks!
Old Jul 20, 2007 | 06:38 PM
afreemanmd's Avatar
afreemanmd
Yeah, I think (not sure but it would make sense) that all the circuits that need a brake signal run off the same switch. So the two are probably related. Have someone see if your brake lights only illuminate when you press really hard on the pedal. My guess is that its either a failing or a misadjusted switch (since it still works)
Good luck!
Isaac
Old Aug 12, 2007 | 08:21 PM
jmelvin's Avatar
jmelvin
I have a 2004 6.0 Powerstroke and it just started doing the exact same thing. I noticed that if you turn the key to the poistion just before "on" it releases the shift lever, then you can start it in nuetral. My brake lights work fine. I hope someone knows the problem. HELP!
Old Aug 12, 2007 | 11:03 PM
TOW4H2O's Avatar
TOW4H2O
The latest with this is that the brake lights are working fine and the cruise and shift lock out work normally if I reach under and fiddle with the switch attached to the brake arm every couple days. I figure it needs to be replaced (not positive but hopeful) but have not gotten around to it yet. The switch kind of pivots and maybe it is getting stuck off kilter a little bit. My favorite online parts place does not list it (or I can't find it) probably should call them and get one but up to my ears in other projects.
Old Aug 13, 2007 | 01:34 AM
Move over I'm coming's Avatar
Just get it from the dealership. I replaced mine in 5min. with only a Leatherman tool. It cost me about $12 if memory serves me right. All dealership parts arn't that expensive and if you own an EX its just a little tough love to buy genuine BLUE OVAL O.E.M.. There is a weird clip/pin and 1 connector to remove/install. Just do it! Rich.
Old Aug 14, 2007 | 02:35 PM
jmelvin's Avatar
jmelvin
Yep! 24 bucks for the new switch and everything is back to normal.
nflfreak43
19
May 22, 2019 10:05 AM
cliffordingles
Jul 14, 2016 11:29 PM
kengarchow
Feb 6, 2016 09:09 PM
FIREPHIL
Dec 6, 2011 08:42 AM
Brent021
Jul 12, 2010 10:01 PM
