Longer to start...
Old Sep 16, 2012 | 08:19 AM
mq1shooter's Avatar
mq1shooter
Longer to start...
Throwing this out there, as to ensure I have not missed something.....HAD a clean Valley after the R & R of the Carter fuel lift pump and just put 400+ miles on in two days and went to start her after a 5 day rest period and she took longer on the crank part to fire...
Popped hood and looked in valley and have a small amount of OIL in the front passage...So me thinks a leakage in the IPR area...Scanned with AE, and data doesn't seem out of placed, so am I missing something ELSE regarding a longer than MY normal start???
weather is warm, and oil is fresh, batteries full, GP's cycle and pull amp gauge down. SO...
Old Sep 16, 2012 | 05:28 PM
427 fordman's Avatar
427 fordman
I had a similar issue, my ipr tin nut was laying in the valley...
I wouldn't think this would be your problem as you've just been down in there, but just sayin it could be loose and you didn't see/notice it.
Old Sep 16, 2012 | 06:35 PM
fordpride's Avatar
fordpride
Check the batts. to make sure you don't have a weak one pulling the other down
Old Sep 16, 2012 | 08:52 PM
oldbird1965's Avatar
oldbird1965
It might be one of the hpop oil rail plugs leaking. Clean things up and keeping checking where the oil is coming from.
Old Sep 17, 2012 | 05:26 AM
mq1shooter's Avatar
mq1shooter
Well, tin nut is secure, I will check the rail plugs, and clean them up...batteries. well, their 2010 Born on date and I would hydrometer them if the tops would come off...I'll trickle charge them to ensure their topped off. I will keep and eye open. thats for the inout.
Darin, how did the gear swap go? and has the gentleman with the 3.55's got his in?
Old Sep 17, 2012 | 07:20 AM
fordman67's Avatar
fordman67
Check hpop resivour level as well.
Old Sep 17, 2012 | 03:12 PM
427 fordman
Gear swap went good shooter. I'm much happier with these gears for towing. I don't know if he got his in yet or not, I haven't talked with him for a while.
Old Sep 18, 2012 | 07:46 PM
mq1shooter's Avatar
mq1shooter
Glad it worked out, I was so close to taking you up on the gear swap also....well there may be others in the future.
Old Sep 19, 2012 | 06:03 AM
427 fordman
I would think there would be someone else to trade with in the future.
Did you figure anything out yet? Find your leak?
ltl_jrw
Oct 26, 2022 07:38 AM
blue66tang95f150
Apr 15, 2017 12:47 PM
IHateCommieCars
Jan 29, 2015 04:43 PM
TBreese
May 13, 2012 03:20 PM
Deerslayinrenek
Apr 12, 2011 11:15 PM
