Overhead display ?
Old Aug 9, 2013 | 11:25 PM
overthehillbill's Avatar
overthehillbill
Had mine repaired by this guy. Been over three years and still like new.
Ford F150 F250 F350 Super Duty Temperature Compass Overhead Console Disp Repair | eBay
Old Aug 10, 2013 | 06:50 AM
Tugly's Avatar
Tugly
I see a lot of mention of the components melting from a foam pad insulating a tiny component, and possibly coming undone again from heat. Nope. The manufacturing process floats the board over a solder bath, or has a robotic device to apply the solder quickly. Mass production frequently leaves a sub-standard solder joint that passes initial tests, but vibration alone will work the uber-thin solder joint loose. Vibration? In our trucks? Naaah. The solder melts at well over 500 degrees F, so I think if anything got hot enough to melt solder - the burnt hole in the foam would indicate this. When we apply solder manually, the solder joint is much thicker - so the road vibration is far less likely to cause an encore performance.
Old Aug 10, 2013 | 02:05 PM
SpringerPop's Avatar
SpringerPop
As Rich mentioned, hand-soldering will leave a thicker solder joint, and is less-likely to fail.
Eutectic (SN63) solder has a melting point of 361 degrees F, and is the most-commonly used solder for surface-mounted devices. Of course, Ford (or their supplier) may have used another alloy, but stuff begins to suffer when exposed to excessive high-heat, and I suspect they used the lowest-melting they could get, i.e. SN63 (or 63/37 if you prefer).
A properly-designed circuit wouldn't allow any component to run as warm as these resistors do. THAT's the basic flaw here, an inadequate design.
Pop
icentropy
Sep 13, 2013 02:53 PM
quality1construction
Apr 22, 2008 10:15 AM
kernman
Jan 25, 2007 10:32 AM
mongo75
Dec 14, 2006 09:44 PM
Green_Dually
Oct 24, 2006 04:41 AM
