Overhead display ?
Old Sep 14, 2012 | 01:48 PM
damonlan's Avatar
damonlan
Overhead display ?
OK i remember reading about this somewhere, but having trouble finding it now. Sorry if this has been answered a million times before.
So I had to do the over head console fix, you know the one cause by some brilliant Mech. Eng. deciding to thermally insolate the entire back of the instrument display circuit board with an adhesive foam, which caused thermal runaway and melted the solder holding the resistors.
Problem is now, my MPG is stuck on 12.6 and I think by temp display is reading 3 to 5 deg high. Miles till empty seems to be fine. Is there a callibration process I should do or a reset or something? Or, should I just purchase a new circuit board and display? From what I remember, these display's are expensive, so I am trying to avoid that.
Oh yeah;
2003 F-350 7.3L DRW Lariat
Old Sep 14, 2012 | 02:02 PM
BigAlsPSD's Avatar
BigAlsPSD
There is a calibration procedure, it's in the owners manual, I'll try to find it.
Old Sep 14, 2012 | 02:07 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I do know while the overhead is showing mpg you can press both buttons at the same time and it will reset the mpg. As far as temp I don't know anything except the temp sensor is in the grill on the drivers side. The sensor is sort of pointy shaped with threads on it.
Old Sep 14, 2012 | 02:08 PM
BigAlsPSD's Avatar
BigAlsPSD
Here it is,
Name:  Compass Calibration.jpg
Old Sep 14, 2012 | 02:12 PM
damonlan's Avatar
damonlan
Thanks guys, I'll try this and get back to you. BTW, does my truck have a compass also, or is this from a later version than the 2003?
Old Sep 14, 2012 | 02:18 PM
guitarpicr's Avatar
guitarpicr
My 2002 has a compass on the overhead -
Old Sep 14, 2012 | 02:26 PM
BigAlsPSD's Avatar
BigAlsPSD
Like stated, Temp is a sensor in the front end, behind the headlight IIRC.
The compass calibration is from a 2000 owners manual...use the E/M button to cycle display.
Here are the 2 pages before the calibration of the compass for a little more info.
Name:  Trip Computer.jpg
Name:  Trip computer2.jpg
Old Sep 14, 2012 | 09:08 PM
X1Lightning's Avatar
X1Lightning
sorry to hijack the thread, but is there a link to the fix for the display? mine is dead
Old Sep 15, 2012 | 12:54 AM
BigAlsPSD's Avatar
BigAlsPSD
Here is one.
Overhead Display Repair.pdf
Old Sep 15, 2012 | 09:20 AM
X1Lightning
thanks for the link!
Old Sep 19, 2012 | 08:14 AM
damonlan's Avatar
damonlan
Remove all the foam pad backing from the PCB
Great link to PDF. Thanks.
I would just add one thing though. Think about it, what caused this to happen to begin with? Well, the answer is, the PCB got too hot. If we repair and return the instrument to the way is was, what will happen? Well, the answer to that is. . . . . . it will happen all over again.
As an electrical and mechanical engineer that deals with thermal dissipation issues on a regular basis, I can tell you that the foam sticky backing on the other side of the PCB is probably what is causing the PCB to over heat and eventually release the solder joints. My advice is to completely remove all the foam backing and the adhesive used to stick it to the PCB. This should prevent you from having to do this repair again in the future. . . I hope.
Old Sep 19, 2012 | 08:26 AM
MTalley's Avatar
MTalley
I don't recall mine having any foam backing or sticky stuff on it. I agree that this could recur over and over again. I seem to remember one of the issues being too little solder or not the correct type for the heat generated.
The calibration procedures given above are only for calibrating the compass. I don't think there is a calibration for the MPG. Hold both buttons while the MPG is showing to reset it to 0 and go from there. If it has been off for a long time, the 12.6 MPG is probably a running average from a very long time ago. Even though the display has been blank, the board has been running and collecting data the whole time.
Old Aug 9, 2013 | 03:19 PM
Splash67's Avatar
Splash67
Originally Posted by BigAlsPSD
Here is one.
Attachment 61329
I hate to dredge up an old dead horse, but can anyone point me to a similar link or set of directions for fixing the lie-o-meter on an '04 Excursion? I think most of the fix is very similar to the one shown in this link, but I'm curious to see what everyone else has learned...it could save me time and embarrassment.
Thanks a TON!!
Old Aug 9, 2013 | 07:16 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Just get one out of an Expedition...same console and computer. Tons of them in junkyards or at site sponsor Hi Tech Body n Paint.
Old Aug 9, 2013 | 09:17 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I had mine fixed fast and cheap by Tanin Auto Electronics.
