torque converter not unlocking
Old Sep 14, 2012 | 08:23 AM
wtroger's Avatar
wtroger
Friend asked about replacing his tranny It is a 4r70w in 1998 f-150 2wd. It stalls engine when you come to a stop, Shop diagnosed it as TC not unlocking. Shop wants to replace the entire tranny for 3g's He doesn't have 3 grand. I was thinking replace the TCC solenoid and see what happens. Any thoughts on this would be appreciated.
Old Sep 14, 2012 | 12:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why randomly replace parts? Is the solenoid bad? Is it a wiring problem? Maybe a stuck valve? How about low trans fluid? Any of those could do it. A little diagnosis could save a lot of money.
Old Sep 14, 2012 | 02:11 PM
wtroger's Avatar
wtroger
Mark I am the one doing the work just trying to find a place to start. Fluid is not low and is in good shape. What items should one check to diagnose this problem
Old Sep 14, 2012 | 02:55 PM
wtroger's Avatar
wtroger
There are no codes active or pending. Brake position switch appears to be working. I think I will disconnect the purple with yellow stripe wire from the transmission connector and see it the TC stays unlocked.
Old Sep 14, 2012 | 03:44 PM
jk080's Avatar
jk080
Transmission Rebuilder
I would not think it would be electrical, its more that likely being applied due to a leaky circuit or its just a bad converter. I very rarely have to replace the tcc solenoid, my first thought would be a missing or deteriorated rubber check ball inside the valve body (#7). You will have to remove the valvebody and its top plate to check, make sure you have new valve body gaskets because the will tear.
f-superduty
17
Feb 16, 2007 05:51 PM
RidinHigh90
Jan 2, 2006 03:36 PM
Donald Cherry
Nov 21, 2005 02:11 PM
A_G
1997 - 2003 F150
Sep 4, 2005 04:21 AM
rocktestr
Sep 9, 2000 12:56 PM
