Stalling in reverse??
Old Sep 12, 2012 | 09:33 PM
Dhughes1's Avatar
Dhughes1
I had this posted in the general pre 97 forum, but was told it would be better over here. My 95 f150 stalls in reverse. It goes fine forward and idles fine in reverse but if I give it quite a bit of gas it starts stalling. We've put a new mlps and that didn't fix it. Then they thought it was the convertor so I got the trans rebuilt and still no change. I'm about to pull my hair out over this deal. I don't even have enough power to back up a trailer or back up a hill. Any ideas??
Thanks, Daniel
Old Sep 12, 2012 | 09:39 PM
Dhughes1's Avatar
Dhughes1
Heres a link to the other thread that has a video of what its doing.
https://www.ford-trucks.com/forums/s....php?t=1188353
Old Sep 12, 2012 | 09:42 PM
jk080's Avatar
jk080
Transmission Rebuilder
If you have the E40D a bad pump can cause this.
Old Sep 12, 2012 | 09:44 PM
danr1's Avatar
danr1
Here's a direct link to the video (posted on Dhughes1 behalf).
D4E0E034-BA81-454E-A425-2F7AEADA3BA7-1777-000001B623CE9743.mp4 video by Danielhughes - Photobucket
Old Sep 12, 2012 | 09:47 PM
Dhughes1's Avatar
Dhughes1
Thanks Danr. Wouldn't the pump have been replaced when it was rebuilt last week?
Old Sep 13, 2012 | 09:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the rebuilder was good and knew what they were doing they would measure the pump and replace it if needed. Maybe they did, maybe they didn't.
You can determine if the pump is good by putting a pressure gauge on it. You can google the specs on the pressures. You need to check it in park, reverse, and drive, both at idle and at stall. Stall is your left foot holding the brake as hard as you can, and your right foot planted on the floor, but for NO MORE THAN 5 SECONDS! Any more can destroy the torque converter.
Old Sep 13, 2012 | 08:17 PM
Dhughes1's Avatar
Dhughes1
When I took the pickup out for a drive this evening, everything started working halfway right. The speedometer started off bouncing then worked right for quite awhile and it barely stalled when I floored it in reverse. The only thing thats different is that its been cold and raining all day. Any thoughts?
Old Sep 13, 2012 | 08:48 PM
Mark Kovalsky
Yes, here are my thoughts.
Old Sep 13, 2012 | 11:00 PM
Dhughes1's Avatar
Dhughes1
I haven't had a chance to get the pressures checked yet, but why would it have all of a sudden started working today? Including the speedometer? The only thing that was still acting up was the abs light was still on.
Old Sep 14, 2012 | 12:30 PM
Mark Kovalsky
In your last post you said it was working halfway right. Now you say it is working fine. This is too confusing for me.
Old Sep 14, 2012 | 02:14 PM
Dhughes1's Avatar
Dhughes1
Well the speedo bounced some at first then it worked fine for probably 20 min. then quit again then went to working again.
Old Sep 14, 2012 | 02:25 PM
khadma's Avatar
khadma
Carpenter Local 745
Like mentioned earlier check the pump first.
I maybe that the two problems could be separate issues.
I know for sure that lower fluid pressures in reverse WILL cause the truck
to stall.
5. Slow
Jan 6, 2010 12:14 PM
ponyrider
Escape & Escape Hybrid
Dec 7, 2008 09:20 AM
Rockafella
Feb 15, 2003 09:09 PM
soupy264
Feb 19, 2001 09:13 PM
