info about s42-ZF reverse
Old Feb 13, 2001 | 06:05 PM
soupy264's Avatar
soupy264
A while ago I asked about strange feelings when going into reverse, with my'90 F-350,7.3 5spd O.D.,bought used
Well I have found out something that might be good for others to know. The ZF 5spd uses a syncronized REVERSE, first one I've ever heard of.
So If anyone normally lets a little grind go on entering reverse,make sure it is not allowed anymore. Because syncro's do not stand much grinding. I'm now replacing the reverse gear and other parts of the rev.syncro, plan to have $300.00 in parts alone.Luckly a friend (pro truck mechanic) and are doing the labor. Just thought the group should know this.
PHIL
Old Feb 15, 2001 | 07:51 AM
ford4x4offrd's Avatar
ford4x4offrd
i have the the same reverse. i roll the truck ahead a little bit before putting it into reverse. either put it in first or start the truck in reverse, theses are ways to avoid grinding, good luck to all
-Jacksland
Old Feb 18, 2001 | 01:01 AM
The Diesel Dude's Avatar
The Diesel Dude
The reverse gear in my 1994 Ranger truck is synchronized. This is my first encounter with a synchornized reverse gear in a manual trans too.
Old Feb 18, 2001 | 11:12 AM
logan_85's Avatar
logan_85
I noticed on my soon-to-be '94 F-350 with a 5spd manual(I don't think it had an overdrive) that the reverse gear also grinded a little. Any chance you might now what type of transmission it probbably has? I bet that it probbably also has a syncronized reverse which is going out. The truck only has 180,000 miles on it, but it still looks great and runs wonderful.
Logan
Old Feb 18, 2001 | 11:56 AM
ford4x4offrd
The only way to really know what you have on there is to get under it and look at the id tag on the side of the tranny. usually mounted on left side. thats all i can help you with, good luck
-Jacksland
Old Feb 18, 2001 | 09:41 PM
ford4x4offrd
Old Feb 19, 2001 | 06:35 PM
soupy264's Avatar
soupy264
I'm not sure, but suspect that the only 5spd is the ZF pronounced ZED_F, until very recently. Now I think there is a 6 spd.
If the trans. has an aluminum case it is most likely the ZF
There is a plate, very easy to see, on the drivers side.
Mine started by occasionally jumping out of reverse while starting to back, then jumping out while backing, then I couldn't hold the shift lever in at all.
In the other 4spd's reverse is a standard gear that actually changes position. in sync'd trans. the main gears are in constant mesh,and only small cogs change position , so if a grind occurs there is no where near the amount of metal to stand the wear.
I replaced the reverse gear and the syncro parts involved, a total cost of $380.00 and expect the labor to cost $150.00 that's because the mechanic I passed wrenches for is a friend who gives me a break Best of luck PHIL
Old Feb 19, 2001 | 09:13 PM
logan_85's Avatar
logan_85
I forgot to mention that only after starting the pick-up the reverse gear grinded a little, and barely would stay in reverse. But, after driving the pick-up a little ways, there was no problem. I do think that everything on the pick-up is probbably heavy duty, it was used for towing I think a large trailer. (weight/length/whatever unkonown) Either way, when I do end up takeing over the pick-up (probbably in 2-3weeks) I have plans to put it in a Ford shop for a little while, the engine doesn't start very well, and while it is in there for that purpose, I might as well have the transmission looked at(whatever trans. it may be)
Logan
guppy
Oct 7, 2021 12:37 AM
Mitch1407
Sep 21, 2012 04:24 PM
boggerted
Apr 14, 2010 09:03 PM
91f2504x4
21
Jan 23, 2009 12:56 PM
bocephus_3349
Jun 30, 2007 06:26 PM
