1978 - 1996 Big Bronco
Headers, egr delete??
Old Sep 8, 2012 | 12:13 PM
frenchy107's Avatar
frenchy107
I have a 96 bronco, first year of OBD2 monitoring. Everywhere I look for headers they only show up to 1995. Is there a way to bypass the EGR valve that comes off the bank 2 manifold? Love the truck as is but this does aggravate me slightly since I want the performance of headers. Any insight will be welcomed
Old Sep 8, 2012 | 11:25 PM
greystreak92's Avatar
greystreak92
This topic has been discussed at length many times. Try searching using the terms exhaust, EGR, or fascinating. EGR cannot be bypassed effectively without causing terrible idle issues. But that doesn't matter because it doesn't port through either exhaust manifold. It ports through the right-hand (bank 2) cylinder head. 96's need multiple HEGO (O2) sensor bungs in the exhaust for the OBD-II computer to function properly.
Any header you use will simply need to have a hole for the OEM HEGO (O2) sensor drilled and the nut that it threads into welded in place. If you don't see '96 listed, check directly with the manufacturers because some will make them by adding the necessary O2 sensor bungs for you.
andy011
55
Dec 21, 2018 08:34 AM
Big Sky Highboy
22
Mar 1, 2015 05:30 PM
jrodimus
Jun 29, 2012 12:59 PM
silver2003fx4
Jan 13, 2011 09:44 AM
BCHauler
Feb 10, 2009 11:30 PM
