Addind headers and removing EGR
Old Jan 13, 2011 | 08:29 AM
silver2003fx4's Avatar
silver2003fx4
I have a set of full length headers that I want to install but I need to figure out what I can do with the EGR system first. My truck is a 96 F150 4x4 with a 351W. The headers I have do not have a port to reconnect the EGR tube. My EGR system doesn't work anyways so I would like to remove it. I can make a block off plate no problem but I know I need to do something with the pressure differental sensor the connects to the EGR tube so I don't set a MIL light.
Is it only possible to do it if you get a special tune or can I just swap in another ECM from another vehicle that doesnt have that sensor? I'm guesing a tune would be better as I also neet to remove the after CAT o2 sensor as well.
Thanks
Old Jan 13, 2011 | 09:29 AM
Conanski's Avatar
Conanski
You can't remove the EGR system on this truck without setting a code, so the only options you have are to install a fully functional EGR system or get a tuner and disable it in the computer.
Old Jan 13, 2011 | 09:44 AM
xxshine's Avatar
xxshine
O.K. to block off the E.G.R. port with a piece of steel. I have 4 vehicles, and all have the E.G.R. port blocked. No problems. Yes, the code will happen, but i ignore it. I put hedders on the Ranger without the E.G.R. tube. Kept the O2 sensor though.
Yaga1973
21
Apr 20, 2025 02:14 PM
Nathan Plemons
May 12, 2015 05:15 PM
southernmudder
Sep 26, 2014 03:00 PM
85fordf150blue
15
Apr 1, 2011 04:17 PM
hugepettyfan
1997 - 2003 F150
Oct 3, 2004 02:31 PM
