Trans pan replacement options
Old Sep 7, 2012 | 04:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
He posted those results not long ago...do a search.... interesting for sure. The ONLY reason I'd change from stock is the rust issue with Ford's fluid containers. Oil, rear end, tranny- it seems they are all rusting pretty quickly! I sprayed mine with Fluid Film and it seems to be working real well!
Old Sep 7, 2012 | 05:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by AGE mechanic
I will always argue that one. It may not be a big difference, but I bet there is a difference. Additional cooling capacity with additional fluid and greater surface area of the pan.
So you are comparing your "I want this to be true" to my actual tests that show it is impossible to cool the fluid in the pan? The air around the pan is hotter than the pan, and the fluid doesn't flow around the pan surface very much, so if you understood thermodynamics you would know that the pan doesn't cool the fluid.
I know you want to believe it, but science is science. It is true whether you believe it or not.
Old Sep 7, 2012 | 05:33 PM
AGE mechanic's Avatar
AGE mechanic
Originally Posted by joe blow
Interesting.....id be curious to read his results
Thanks for the help everyone
I have never seen results of any testing. People are only stating their theory's.
I look at it like this. It takes X amount of BTU's to raise the temp of one quart of fluid 1 degF. If you add 5 additional quarts, you have essentially added heat carrying capacity. Those same BTU's will not be able to increase the temp to the same level as it did with the single quart.
Another way to look at it on a grander scale. Look at a CNC machine. Imagine if you only had 2 quarts of the cutting fluid, (which is used for cooling.) At some point the fluid would get up to a stable temp. Now increase the capacity of the cutting fluid. The temp will be less as you increase capacity.
Now adding 5 quarts of Mercon SP may not add much, I believe it adds some BTU carrying capacity. Now, add the increased surface area of some pans with fins or tubes. I believe you will see a difference, it may be negligible, I don't know. If nothing else you have a nice drain plug and a boss to add a temp gauge if you like. BTW, I do understand thermodynamics.
Old Sep 7, 2012 | 05:49 PM
69cj's Avatar
69cj
Stock pan already has a drain plug and I'll take the word of a past tranny engineer over the theoretical posibilities of a back yard mech. Take no offense, I consider myself a back yard mechanic and a lot of the I know it works that way myths of my youth have been scientifically shattered. Can't believe how the older, than me, generation lived so long being so stupid.
Old Sep 7, 2012 | 07:02 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Join the older generation, CJ..... At 73, I'm STILL learning!
Old Sep 7, 2012 | 07:14 PM
Misky6.0's Avatar
Misky6.0
Too funny! "We" had toys that were choking hazards, no cell
Phones, no internet, Cars wih only lap belts and no cable tv.
Natural selection kept idiots from breeding.
now they are protected like an endangered species.
Old Sep 7, 2012 | 07:26 PM
joe blow's Avatar
joe blow
Looks like I may default to my original plan of purchasing an '08-'10 pan and filter.....might be a waste of money for essentially "bling"! Anyone here done the conversion i speak of? Since the newer pan comes with an internal filter is it necessary to use the bypass toilet paper roll filter in the front as well?
Thanks again
Old Sep 7, 2012 | 07:31 PM
bismic's Avatar
bismic
The new internal filter is a full flow filter. It is a good thing. I would still keep the external filter, but I have seen posts from folks saying you can leave the external element out of the housing after doing the mod.
Old Sep 7, 2012 | 07:33 PM
69cj's Avatar
69cj
Thanks again
The 08 and up actually has an internal filter that works and yes you still want to change the external filter. They are the cheapest alternative that I know of that does some good.
Old Sep 7, 2012 | 07:43 PM
AGE mechanic
I would like to see your testing on this Mark Kovalsky, I must have missed it if you've posted it before.
Old Sep 7, 2012 | 08:18 PM
Mark Kovalsky
Then you should be able to understand that the air around the pan is usually hotter than the pan temperature. If you understand thermodynamics you understand that air that is hotter than the pan CANNOT cool the ATF.
Get a job at Ford in Automatic Transmission Engineering. The data is stored there. The testing and the results belong to Ford. When I left it stayed there. I will not be posting them.
Old Sep 7, 2012 | 08:35 PM
joe blow's Avatar
joe blow
That sounds great guys......I searched on ed parts guy for the part numbers and found some , but Id like some clarification.....dont want to order the wrong stuff...any ideas on the 3 part numbers ('08 pan, filter and gasket) I need to order this stuff?
Thanks again Mark K for the engineering insight and thanks to all for their input
Joe
Old Sep 7, 2012 | 08:48 PM
  #28
bismic's Avatar
bismic
08 transmission pan 8C3Z-7A194-B
08 transmission pan filter 8C3Z-7A098-D
The gasket is re-usable
Here are pics:
http://www.powerstroke.org/forum/6-0...n-install.html
Old Sep 7, 2012 | 09:01 PM
  #29
AGE mechanic
As a matter of fact if the air was hotter around the trans pan it would be absorbing heat. Heat does in fact travel to cold, the greater the delta the faster it travels.
The air around the trans pan is NOT hotter than the pan on most of our trucks. You can say what you will about exhaust pipes and front air dams. Traveling 45-80mph on an average day in the US, the air across that pan is not hotter.
Its great that you worked with these trannys years ago. It really is. But maybe that's what is keeping YOU so hung up on thinking it is perfect in completely stock form. I preform development testing on turbine engines for a living, so yes, I do know a bit about thermodynamics. Nice how you throw in the higher temp statement while attempting belittle my knowledge. Nice try
If you have no proof of your testing we cant see the test conditions you speak of. So I'm going to tell you that I think you are wrong. I wont continue to argue with you about it.
Moving on now if you can keep it zipped shut???
Old Sep 7, 2012 | 09:36 PM
  #30
Mark Kovalsky
Once again your no data, just imagining things trumps my test data.
Here is one statement of yours that I agree with. I know you are wrong. I won't continue to argue with you about it.
Apparently I can't.
