timing question
Old Sep 6, 2012 | 05:13 PM
ewellman's Avatar
ewellman
timing question
What should the timing spec be with the spout unplugged and plugged in?
Old Sep 7, 2012 | 02:02 PM
AbandonedBronco's Avatar
AbandonedBronco
What year engine/truck do you have?
Old Sep 7, 2012 | 02:15 PM
ewellman's Avatar
ewellman
1992 F150 4.9l 300 inline 6
Old Sep 7, 2012 | 02:53 PM
AbandonedBronco
I believe the stock timing for the EFI engine is 10°.
There should also be a sticker/decal on your radiator support that has the vacuum diagram for the engine, as well as the timing.
Old Sep 8, 2012 | 09:06 AM
6978sghfbjklgdfsjhkl's Avatar
You should set the timing with the spout unplugged I believe, and most EECIV motors are set at 10. When you plug the spout back in..the puter decides what the timing needs to be based on what all the other wire-connected things are reporting.
Supergordo
Nov 13, 2011 11:36 PM
Benyaytugar
Mar 13, 2007 09:23 PM
The67Beast
Jul 7, 2006 08:11 AM
Boldt
19
Jan 8, 2003 11:51 AM
