Running 302 without ps pump??
Old Sep 3, 2012 | 08:18 PM
52' fordnut's Avatar
52' fordnut
Hello,
I have a question for you guys who are running a 302 in your 52 ford.
I am going to go with manual steering in my truck, yes I know that power steering is awesome, but I would rather use manual.
My question is, can I run the 302 without the power steering pump pulley being there? Like run a belt from the crank pulley up to the fan pulley?
Any help is greatly appreciated!!!
Thanks a million!
Jon Preston
Old Sep 3, 2012 | 08:41 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I am, Im using the stock steering box, so i took off the second pully and only have one belt. as long as you dont have a power steering box or power rack your fine. but if you do have a power box or rack you would not be abel to steer without the pump turning. I hope this answers your question. Edit , I should mention to make sure the second belt or pully isnt running something else like a air pump ect.
Old Sep 3, 2012 | 08:51 PM
52' fordnut
Awesome!! Sounds great!!!
Thank you for the help!!
Jon Preston
Old Sep 4, 2012 | 10:25 AM
dawolverine's Avatar
dawolverine
Yup its no problem - the pump is effectively an accessory that happens to be run by the engine.
Old Sep 4, 2012 | 05:24 PM
52' fordnut
Quick question......I'm trying to put my 302 on an engine stand and I have 3/8 bolts to mount the engine on the stand but they just go in the hole and pull right back out they don't even thread in, what size bolt do I need for the rear of the engine to mount the engine on a stand???
Old Sep 4, 2012 | 05:51 PM
BlueOvalRage's Avatar
BlueOvalRage
Smallblock Ford bellhousing bolts are 7/16" - 14 TPI.
BigBlueCat
Jun 20, 2017 08:57 AM
oxt127
Dec 29, 2015 09:22 PM
elinmon1976
Nov 1, 2009 01:35 AM
science_rules
1978 - 1996 Big Bronco
Feb 3, 2003 07:29 PM
