302 pulley belt question - Ford Truck Enthusiasts Forums
Old 06-18-2017, 02:48 PM
BigBlueCat
BigBlueCat is offline
BigBlueCat is starting off with a positive reputation.
Guys,
Putting a power steering pump on my 48 Ford f1 302 engine as part of the toyota power steering conversion. Can anyone suggest how I handle the ps belt. Do I just add a longer belt? Also, if longer belt is all that is needed should I put it on the inside or outside?
Old 06-18-2017, 04:30 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
The 302s that I have seen with v-belts run the alternator off the engine side pulley and the PS pump off the radiator side pulleys. I would mount the pump first and check the belt alignment then run the belt from the crank to the water pump to the PS pump and back to the crank. Here is a pic of a 302 showing the pulleys/pump:
Old 06-18-2017, 05:07 PM
The Outlaw's Avatar
The Outlaw
The Outlaw is offline
The Outlaw is gaining momentum as a positive member of FTE.
The alternator will be run off of the pulley groove that is closest to the engine.
The power steering ring pump will use the other groove of th crank pully
Check out cvfracing.com. Nice quality brackets for a good price. They make brackets for both the stock and saginaw pumps. You can also get the belts right from them as well.
Old 06-19-2017, 07:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
GreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to allGreatNorthWoods is a name known to all
Here's a picture of mine. I used a Saginaw pump from an 87 Chrysler and made my own bracket since I had a Chrysler T-bar front suspension but maybe it will give you some ideas...
Old 06-19-2017, 09:33 AM
Mr. Ed
Mr. Ed is offline
Mr. Ed has a good reputation on FTE.Mr. Ed has a good reputation on FTE.
I found this on the internet for 302/351W.
I tried to post it here but it won't go. So type in 70grabberbelts in the google search bar and it will come up under the images section.
I used this diagram to get the correct alignment and more important, the correct part numbers. As for the pump, I bought the new Borgensen Saginaw pump and brackets specifically for the 351W.
Later!
Mr. Ed
Old 06-19-2017, 09:57 AM
The Outlaw's Avatar
The Outlaw
Mr. Ed
Is this what you were looking for? I'm not sure I agree with it if it is? I know this is not how my 1968 302 is setup. I put below a pic of the system I just bought for my engine. This show the belts the same way my engine is.
I should add that my setup is the saginaw pump not what is shown here.
Old 06-19-2017, 12:44 PM
matthewq4b
matthewq4b is online now
matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.
Have you considered just ditching the V belts and going to a 79 and later Panther (Crown Vic Grand Marquis Town car) serpentine system.
Old 06-20-2017, 08:57 AM
Mr. Ed
Mr. Ed is offline
Originally Posted by The Outlaw View Post
Mr. Ed
Yep. That's it. I have a 351W with a single pulley and need to add PS and eventually A/C so I bought the correct pulleys as shown on the drawing and as I type, are being installed on the truck.
I too have the Saginaw pump and it is mounted on the right (driver's side) of the motor. I bought the set up and it says Borgensen.
Later!
Mr. Ed
Christopher Workman
02-09-2018 09:25 PM
ericford1984
10-01-2017 10:10 PM
Delkancott
10-01-2017 08:11 PM
Delkancott
1999 to 2016 Super Duty
09-29-2017 12:38 PM
nbtone
15
05-11-2016 09:36 AM
Quick Reply: 302 pulley belt question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
