Don't know how long this is going to last, but Murphy USA is giving 10 cent a gallon off when using a Walmart gift card to buy fuel at there stations, usually at the one's out in front of the Walmarts.
it may be 10 cent cheaper but that stuff is not gas or d2. it runs like @#$@#.
i used it some and got 2 mpg less, it is was over 4 tanks will not run it angina.
Matter of fact, I filled up at one earlier today on the FL panhandle and drove home to central AL with no problem. Overhead (previously verified several times as pretty accurate) gave me a 19.6 mpg average (55-65 US highways, 67 on the interstate) on my dually with two passengers on board. It was 20.9 before I hopped on the interstate.
Never seen a problem with it in either my 5.9 cummins or my 7.3. My closest one is about 30 minutes away, but I may have to call and verify it and may fill both of them up. Its usually 2-3 cents off and thats it.
I use the Murphy near my house all the time because its near my house, has the best price and moves allot of diesel. I also got a Walmart Discover card and get a .5 cent a gallon using it. When I filled up yesterday I got a .15 cent gallon discount. I have had no Ill effects running it.
maybe i got a bad run?
the local shop sells a ton so it is fresh and they are there cheaper then most of the big shops.
at the shell it is 4.01 the local shop it is 3.87 and no bio in it
