Running 100% Ethanol
Old Dec 9, 2007 | 02:48 PM
Gen 1 driver's Avatar
Gen 1 driver
I've got a 94 F350 with a 460. I was wondering id anybody had looked into running 100% ethanol. I'm curious what mods may be required. I know it can eat up some rubber and plastic. Mods to fuel lines?
Just curious. Lots of advantages .
Would love to hear others ideas. I hate paying $3.00 per gallon while getting 10MPG.
A sharing of knowledge would be appreciated.
Mike
Old Dec 9, 2007 | 03:49 PM
jroehl's Avatar
jroehl
Ethanol has less energy per gallon than gasoline (read: even lower MPG), and the only reason it's cheaper right now is that it is heavily subsidized, by your tax dollars. You would have to totally reprogram your truck's ECM along with replacing all the non-compatible fuel system components.
Much of the mileage data now suggests that even though it's cheaper, the lower mileage you get more than wastes that price difference, so using gasoline is cheaper in the long run, especially once you factor in the cost of any mods you'd have to make.
Jason
Old Dec 9, 2007 | 04:16 PM
dhag911's Avatar
dhag911
here e85 is 60-65 cents a gallon cheaper. so running e85 in my taurus is a lot cheaper. if you get 4 mpg less to break even you would have to pay 40 cents a gallon for it. right now i am getting about 22 city driving on e85 my sister wife her sable get about 16-18 city driving. so i see if it is at least 20 cents a gallon cheaper i will use it for sure maybe even if it is 10 cents cheaper since i dont see how i can get an extra 4 mpg in the city with it
Old Dec 9, 2007 | 04:18 PM
dhag911's Avatar
dhag911
here e85 is 60-65 cents a gallon cheaper. so running e85 in my taurus is a lot cheaper. if you get 4 mpg less to break even you would have to pay 40 cents a gallon less for it. right now i am getting about 22 city and short highway driving on e85 my sister with her sable get about 16-18 city driving. so i see if it is at least 20 cents a gallon cheaper i will use it for sure maybe even if it is 10 cents cheaper since i dont see how i can get an extra 4 mpg in the city with it
Old Dec 9, 2007 | 04:55 PM
1just4don's Avatar
1just4don
I have 'heard' of alot of people experiemnting with 50% regular-50% E-85. They ramped up 'slow' so they could tell IF they were having problems. That saved them some in gas cost and could track any milage issues too. When E-10 or 15 came out way back when I had a 75 Taurus (6 cyl.)and always got better mileage on it vs regular by a mile or two. NOW they say its the other way around,,,I GUESS each car is different!! NO issues back then even when people were bitching about fuel filters etc. ,,cant say I ever had that!!
IF ethanol is really all that bad and power less then why are racers running it?? Drag and circle track?? Something doesnt add up!!
Old Dec 9, 2007 | 05:05 PM
jroehl's Avatar
jroehl
Racers run it because it has high anti-knock properties, so they can run higher compression ratios.
It's bad not as a fuel in and of itself, it's bad because it's a waste of resources to make it.
Jason
Old Dec 9, 2007 | 05:20 PM
85e150's Avatar
85e150
There are safety issues (like it goes up easier and you can't see the flame) and water absorption problems with 100% ethanol.
Yea, the racers use it with high compression and they dump it into the cylinder with a 1" hose because it will burn at those ratios where gas needs 14.7 : 1 or so to burn. So yes, you can take a fuel that is 70-80% as powerful as gasoline but use 3 times as much and make more power.
Old Dec 9, 2007 | 06:37 PM
airmetdave's Avatar
airmetdave
Jason
Hmmm... Supporting OPEC is a better use of resources???
Old Dec 9, 2007 | 06:59 PM
jroehl's Avatar
jroehl
It's not about OPEC...it's that it takes more energy to produce it than it contains, plus it shifts some of our agriculture from food production to fuel production.
This really isn't the place (no politics and the like are allowed outside ClubFTE) to debate the hows and whys of ethanol, I just gave my opinion that it's a raw deal.
Jason
Old Dec 9, 2007 | 07:09 PM
jnewkirk77's Avatar
jnewkirk77
I use E85 in our Dodge Caravan whenever I can find it. It's getting to be more widespread, and that's a good thing. Even with the mileage drop-off, in most places the price offsets that.
Gen 1, I am considering installing one of the Flex-Tek systems (which enables any fuel-injected vehicle to use E85) in my truck. Of course, that's pending a general overhaul. I think you can get a F-T system to work with your 460. Not 100% sure on that. If you are planning to do it, perhaps you can work with the tuning and increase your mileage.
Personal opinion here: The automakers could make flex-fuel vehicles get better mileage with E85 if they'd just tune them properly or allow for automatic adjustments dependent upon the fuel. But they haven't had their hand forced yet
Old Dec 9, 2007 | 10:49 PM
jroehl's Avatar
jroehl
Well, as long as you remember it's only an opinion, because if an automaker could tune a flex-fuel vehicle to get better gas mileage with E85, they could tune it for better mileage with gasoline. The problem is that E85 only has about 70-75% of the energy per gallon that gasoline does, so there will always be that limitation.
Ethanol is fine as an anti-knock/oxygenate additive, but it's lousy as an energy source for a vehicle. It's just another environmental feel-good short-sighted "solution".
By what I heard in elementary school in the late '70s/early '80s, our country should be running entirely on wind, solar and hydro-electric power. Those together total maybe 10% of our power production in this country. E85 is no different--it's piddle power.
Jason
Old Dec 10, 2007 | 12:20 PM
Gen 1 driver
Lots of interesting thoughts. As far as cost. My thought was making it myself for my use. Goverment allows up to 10,000 gallons/ yr. I won't be making anywhere near that much. I've researched may sites on the net.
I appreciate the discussion of various pro's and cons. what I have not seen in my surfing is a discussion or comments by someone who has actually run a 90's F series truck and what mods they felt were needed.
The tune is not an issue. For a couple hundred bucks I can get a programable chip and retun the truck. My son and I run modified Gen 1 lightnings at the drag strips in town and have both Dyno tuned. I'm ok with having to change filters a few times while it is cleaning out the fuel system.
I'm curious what if any seals or hoses ethonal will eat away.
Old Dec 10, 2007 | 03:12 PM
airmetdave's Avatar
airmetdave
Jason
Cheap hydrocarbons have made you dependent on one way of seeing things...
If politics aren't allowed here then I would ask you to keep your socio-political opinions to yourself...
Old Dec 10, 2007 | 04:05 PM
dyoungen's Avatar
dyoungen
I have found using a gallon or 2 in a full tank of gas helps clean the fuel system and is a lot cheaper than the pints of fuel treatment (STP, TECHRON ECT) that sell for a couple of dollars and does as good or better job on buildup in the fuel system.
Old Dec 10, 2007 | 05:28 PM
jroehl's Avatar
jroehl
Wow, you must know a lot about me in just a couple posts. Are you psychic? Wait, no, you can't be, because you didn't come close to being right with the above statement.
I've been here long enough to know that stating my opinion that ethanol is a raw deal in this country is one thing. Debating WHY it is a raw deal is another story and would likely draw the fire of the moderators or admins.
Jason
