77 400 timing gears
Old Aug 31, 2012 | 11:44 PM
79super460's Avatar
79super460
77 400 timing gears
So I'm wondering what's the best and cheapest route for timing gears. I've read that you can put early 70 gears and chain in does this work some say yes some say no? Just looking for some opinions or maybe some other options thanks.
Old Sep 1, 2012 | 12:01 AM
hav24wheel's Avatar
hav24wheel
So do you want timming gears, as in a gear drive? Or some timming gears for a timing chain to run on?
Old Sep 1, 2012 | 12:32 AM
mark a.'s Avatar
mark a.
Yes you can put the older stock replacement gears on, they will have the straight up timing. The later stock replacement sets will be retarded and you don't want that.
Old Sep 1, 2012 | 06:48 AM
79super460's Avatar
79super460
Looking to go with gears and chain.
Ok that's what I was thinking but I was looking around and some were saying that the gears wouldn't do anything because the retarded timing was actually in the cam itself. So I was thinking I was going to need a offset key or something.
Old Sep 1, 2012 | 11:50 AM
montana_highboy's Avatar
montana_highboy
X2, you asked for the cheapest route so i assume you're just buying a stock replacement timing set.
Ask for a pre '72 set, after '72 they'll be retarded 4 degrees.
Old Sep 1, 2012 | 07:44 PM
1960fordf350's Avatar
1960fordf350
even the sets for the older engines are retarded. do your own search on autozone or advance and they use the same timing kits for all years, even to early 70's. Spend an extra $20 and get the Summit chain that stands it up straight.
Old Sep 1, 2012 | 08:32 PM
montana_highboy
You are right sir, i stand corrected....i have FE's on the mind today, where there is a split between stock timing sets between '72/'73.
I concur with you though, fork over the extra 20 bucks and buy a straight up timing set from Summit or Jegs.
Old Sep 1, 2012 | 09:01 PM
79super460's Avatar
79super460
Thanks a lot guys I don't know a much as I should with motors yet. Stuck on being a body man
Old Sep 1, 2012 | 09:29 PM
79super460's Avatar
79super460
Another quick question is what are your thoughts for a intake. It's all stock 400 with headers and I am planing on putting a edelbrock 1405 carb on which just an extra one I have. Thinking either the weiand 8010 or edelbrock performer. Opinions?
red bud
Oct 17, 2007 10:48 AM
Munch
Apr 6, 2006 11:11 PM
Walking_Tall_0403
Oct 29, 2003 03:06 PM
ecube
1978 - 1996 Big Bronco
Mar 30, 2003 12:02 PM
rsrxc700
Mar 5, 2003 01:27 AM
