Question on regen
Old Sep 10, 2012 | 10:21 AM
  #31
Native Tex's Avatar
Native Tex
Originally Posted by gsxr1300
That cleaning exhaust is an active regen
Thanks.....where do I see the soot levels refered to above. I only see the exhaust cleaning notification.
Old Sep 10, 2012 | 11:44 AM
  #32
Hdslider's Avatar
Hdslider
You will need a edge CTS to see soot level.very nice peice of equipment.
Old Sep 11, 2012 | 07:22 AM
  #33
vinnie45's Avatar
vinnie45
passive regain?
Tell me more...... I am pulling my 43 ft 5er, and my regain flashes on.... Pisses me off. Like only getting 9.5 to 10.5 isn't bad enough, now this **** thing kicks in and milage goes to 4. Tell me what I need to get rid of this crap for good..................................
Old Sep 11, 2012 | 09:06 AM
  #34
donovan's Avatar
donovan
So you have 43 foot 5er that weights about 13 to 15 loaded. I would say 10 MPG is good for that setup.
Now about the 4 MPG. Who often does your truck regen durring your pull? It should be RARE. I have not seen my truck go into regen while pulling. If you have a edge insight what are the soot levels before after you pull.
The other option is to delete the DPF and EGR and the SCR. That is not a option for me as I live in CA which has yearly smog test for diesels.
Old Sep 11, 2012 | 09:16 AM
  #35
kper05's Avatar
kper05
So without resetting the MPG calculator when you began a regen, it went from 9 to a 4 average?
Instant or resetting it when the AR began I could see 4 MPG during the AR duration.
I reset mine after each fillup. I usually fill at 1/4 tank remaining.
One regen has about a 1 MPG impact over the 3/4 tank I burned.
Jeremy Thornton
Jun 2, 2018 05:29 PM
backtrack2015
Dec 12, 2017 08:27 AM
747Driver
6.7L Power Stroke Diesel
24
Apr 17, 2017 07:20 AM
breeno
Dec 30, 2013 10:09 PM
StanleyZ
6.4L Power Stroke Diesel
17
Oct 17, 2012 12:22 PM
