Great 5700 mile Summer Trip
Just completed my summer trip. 7 weeks, 5700 miles, probably around half towing the 5er, one oil change in Michigan. ATL up Nashville and Indy then through michigan, across the UP, over to minneapolis and then back to ATL. With a lot of stoups and touring. Truck was perfect, pulled like a young mule. I only checked the mileage on one tank. From just north of the IL. state line to Paducha KY. I think it was 540 miles and a hand measured average of 11.2 MPG. Best I've ever gotten towing and I'm thinking maybe I didn't get it full but it sure seemed to be full. Might have had a tail wind. Anyway, I'll take anything over 10 so I'm happy. I now have put 50,000 miles on the truck for a total of 54000 and have had no real problems. Just thought you would like to know that some of these 6.4s have done fine.
Great 5700 Mile Summer Trip
Just got back from a 5450 mile trip from Michigan out to Portland, Or, up to Seattle and back through Yellowstone, Devils Tower and Mt. Rushmore pulling an 11,000 lb 5er. 559 gal of diesel and a trip average of 9.75 miles. The '10 F-350 SW CC ran like a top. Only frustration that I had was regens during mountain climbs. Once I started up a pass the truck would go into a regen (I realize that is where I was generating max soot) and it would reset the regen several times due to the high boost and high soot generation. Pulled up over Granite Pass in Wy at 10 miles of 8% grade with one transmission overheat warning from my Edge. Pulled over and took some pictures while it cooled down and then made the rest of the climb without issue.
Neil Schiller
'10 F-350 SW, Stock with Edge programmer as gauge pack while towing
2011 Bighorn 3185 at about 11,000
Neil Schiller
Didn't know where it was. My sister in law and their big family live in lakeville so we were pretty busy. But, I do have a question. What are y'all doing about the mandatory bio out there. They were already supposed to be at B20 this summer but pushed it back.
My Edge Evolution is set for warnings at 232°F. My research shows that a tranny temp of 250°F can be sustained for 1 hour. The warning came just as we approached a turnout on the way up, so I stopped and we took some photos while the engine idled and the EOT, ECT and TFT temps came down. I have my Edge Evolution set with ECT (top left), EOT (top right), TFT (bottom left) and EGT (bottom right). When not towing I set Boost, EOT, Bat V, and EGT. I tow in stock mode and run in mode 1 otherwise.
I'm running the stock 3.55/1 rear end. That was one of my big concerns when we took off for the trip, but it handled everything just fine. I was impressed at still passing the big rigs going up hill and the engine braking was good coming down hill. My only complaint was the regens while going up hill where the regen would reset every time boost would exceed 30 psi. It made for some long regens in some of the hilly areas.
I had that discussion on this forum a couple years ago. Consesus was that I was wrong. But I continue to believe (know) that there is some loss of power from the high ratio rear axles. There is some grade/load that I can pull with my 4.30 that you won't with a 3.55. Now whether we would ever encounter such a hill or load is a different question. But I feel pretty sure that the hot tranny is a result of the 3.55 rear axle. I tell ya, with the dpf off and the 4.30 rear end I think this truck could pull my trailer up a pine tree.
Sometimes I would rather have 4.30's. Seems that the 3.73 is the best combo for me though.
