where to tap for 12v for my choke
Old 08-26-2012, 05:14 PM
husker77's Avatar
husker77
husker77 is offline
I don't have a good wiring diagram, the ones on the internet I am finding are hard to read. But anyway any opinions on ign switched 12v to tap into that is close to the carb?
Truck is a 1977 f100 2wd 400m, installing barry grant road demon carb.
Old 08-26-2012, 05:26 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
armstrongfordtrucks is offline
There is a wire hanging from the firewall with a plug on it. right about the heater to center of firewall. I believe it also goes to the hi idle on the otherside of carb.
Old 08-26-2012, 06:11 PM
husker77's Avatar
husker77
husker77 is offline
Found it, worked perfect, many thanks.
Old 08-26-2012, 07:20 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
The "S" terminal on the alternator is the factory location.
Old 08-26-2012, 07:59 PM
husker77's Avatar
husker77
husker77 is offline
Thanks, I might rewire it later, but it is working fine now. The wiring is a terrible mess anyway, so I want to put in a new harness later.
Old 08-26-2012, 08:37 PM
armstrongfordtrucks
Courious, are you saying the other end of the plug goes to the "S" or all 5 of my trucks were re-wired from previous owners.
Thanks
Old 08-26-2012, 09:08 PM
J ballan's Avatar
J ballan
J ballan is offline
I believe they were hooked up to the alternator so they would only send power to the choke when the engine is running. I assume they did this just in cases someone had the ignition on and the engine off for an extended period of time the choke would still function when the engine was started. I hooked mine up to a oil pressure switch that I installed under the oil pressure sender. Good luck
Old 08-26-2012, 09:10 PM
husker77's Avatar
husker77
husker77 is offline
I was thinking of that possibility but I figured it shouldn't be that big of a problem. Maybe when I do the 3g alt swap.
Old 08-26-2012, 09:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Thanks
The factory set-up had a white wire w/ black trace run from the "S" (stator) terminal on the alternator to the automatic choke terminal on the carb. The output of the stator is AC not DC voltage, if you measure it you'll see ~6-7 volts. From the factory the electric part is an assist to the exhaust heat to open the choke while on aftermarket carbs are 100% electric.
I've heard from several people who have hooked the aftermarket carb up to the factory location and report no problems with choke operation. This is how I have mine (390 4V) hooked up but I can't report on the choke because I haven't started it yet.
Old 09-28-2012, 05:10 PM
joel79ford's Avatar
joel79ford
joel79ford is offline
Hey guys im also having an issue with my truck
I know where the negative cable goes to, but im still confused in where my positive cable should go to?
Old 09-28-2012, 05:25 PM
V10man's Avatar
V10man
V10man is offline
Here is a pic of the conector on my truck. The po cut and added the red wire. I put it on my Edelbrock choke and it worked great.
Old 09-28-2012, 05:26 PM
jim collins's Avatar
jim collins
jim collins is offline
Neg. bat.cable to engine block ,another one from block to frame.
pos. bat. cable to starter sol.
another cable from other side of sol. to starter.
Old 09-28-2012, 11:57 PM
joel79ford's Avatar
joel79ford
So I can connect it to the starter sol.?
Any where else?
can I connect it to a fuse?
Old 09-29-2012, 12:00 AM
V10man's Avatar
V10man
V10man is offline
As long as it is a key on power go for it.
Old 09-29-2012, 03:14 PM
joel79ford's Avatar
joel79ford
OK, radio fuse should be OK right?
Quick Reply: where to tap for 12v for my choke
