Vent window repair
Old Aug 24, 2012 | 09:47 PM
jimhackney's Avatar
jimhackney
Vent window repair
Hey guys, I'm in the process of replacing all the door glass weatherstrips. I have removed everything and am now repairing, cleaning, painting, etc all the parts. My vent window handle has been broken off and so need to replace the handle. I have all the parts to repair it, and looking for advice on how you get the vent window glass out of the vent frame. Some time back I read someone's "how to" but can't find it again. Any advice, or links to the process?
Old Aug 24, 2012 | 11:33 PM
52 Merc's Avatar
52 Merc
The best advice is to take them to a local auto glass shop and have them remove them for you. They'll have the proper tools and experience to make easy work of it. If you're totally bent on doing it yourself, try warming the frame with a heat gun or other similar heat source to soften the bond and pull on the glass really hard (attempting to) separating the glass from the frame.
Old Aug 25, 2012 | 02:16 PM
BigPigDaddy's Avatar
BigPigDaddy
I agree with Wayne. My brother has been doing auto glass for about 25 years and he can do that stuff in his sleep. You could probably drop it off while you run some errands and pick it up an hour later.
Old Aug 25, 2012 | 02:20 PM
badger_hound's Avatar
badger_hound
I'm the same boat Jim. Sounds like a glass shop is the way to go!
Old Aug 26, 2012 | 02:17 AM
jimhackney's Avatar
jimhackney
Thanks. Being bone headed, I went ahead and clamped the glass to my workbench and gently tapped it off with a wooden block. Came off pretty easily with gentle persuasion from the wooden block. Now to sand, prime, paint, put it back in with the new lock post. Any good ideas about what to use to repaint the inside of the door?
Old Aug 26, 2012 | 03:51 AM
bigdaddylove's Avatar
bigdaddylove
Me, too. This is one of those things that I'd rather save and pay someone to do because I'd go through so many windows, it would be crazy expensive.
4EyedTurd
May 1, 2019 03:04 PM
scottlathrop
Aug 2, 2015 08:04 PM
ungerp
Jan 2, 2013 03:54 PM
littlecobra1977
Nov 7, 2011 08:54 PM
3414
Apr 16, 2011 12:20 AM
