E4OD Pressure gauge
Old Aug 26, 2012 | 10:12 PM
  #46
halaferd's Avatar
halaferd
Hey this is great... I have all the questions and I have all the questions haha
You have no idea how much I appreciate the help.
Old Aug 26, 2012 | 10:16 PM
  #47
halaferd's Avatar
halaferd
Well clearly I don't have all the abilities to talk/type haha I meant YOU have all the answers... Huhh anyway I'm going to play w the TPS a little more, I'll update if I get the sweet sweet spot
Old Aug 28, 2012 | 12:14 PM
  #48
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Originally Posted by FORDF250HDXLT
yeah.just to be clear though,as that sounded a little suspicious lol.grounding it to the alternator case will do the trick.
i tested for my water in fuel light this morning and i got no light on the dash when i stuck a wire in then of the plug that goes onto the fuel filter base and grounded it to the alt.
Old Aug 28, 2012 | 01:32 PM
  #49
FORDF250HDXLT's Avatar
FORDF250HDXLT
blown "water in fuel" light bulb in dash or bad wire probably.should be fixed so your notified if or when it happens.
Old Aug 28, 2012 | 02:33 PM
  #50
'94IDITurbo7.3
what lights in that little cluster are supposed to light up when i start the truck? they should do a test of the bulb right?
when i start the truck i only get engine temp light and another red light i will pay more attention later when i start it.
Old Aug 28, 2012 | 04:03 PM
  #51
halaferd's Avatar
halaferd
So I can't find a t17 torx bit that fits the bolts on the TPS bracket. I've been making a 15 and a pair of vice grips work but that has come to an end and it's just a crappy halfA way to do things.
So, does anyone know...
-where I can get a T17 bit
-where I might get replacement bolts
-if I can swap the bolts for some Allen head ones that are threaded all the way?
Not an emergency, bc I'll just do some fancy work on these to make them work, I'd just rather it be a little cleaner than my engineering.
Old Aug 28, 2012 | 04:27 PM
  #52
'94IDITurbo7.3
i check my lights that i get when i start the truck. i get the read engine temp light and the read fuel filter light.
Old Aug 28, 2012 | 05:42 PM
  #53
halaferd's Avatar
halaferd
Mine isn't hooked up but I believe it should light up, if I remember correctly when you turn the key on prior to start up. I bet the bulb is bad.
  #54
halaferd's Avatar
halaferd
I'm sure mine is too
Old Aug 29, 2012 | 01:32 PM
  #55
halaferd's Avatar
halaferd
Does the antilock/speed sensor on the rear diff on my '91 tie into the trans also?
Because my light is on, I've done some wire checking but how do I check the sensor? Saw a post on it, but it didn't seem right.
Old Aug 29, 2012 | 05:00 PM
  #56
kobaltblue's Avatar
kobaltblue
On a 91 the VSS is on the tranny
Erratic Shifts
Bad VSS
Can cause erratic shifts and LU problems. May or may not set code 29/452 (VSS speed
sensor signal to low).
Note
VSS is located in transmission tail housing or differential.
To check VSS
1. Remove 2-wire connector end.
2. Hook DVOM meter leads to pins on sensor. It doesn't matter which way you hook
up the red or black leads.
3. Set scale to AC voltage / 0 to 40 volt scale.
4. Raise vehicle so rear wheels are off ground.
5. Start vehicle, put in 'D" and make transmission upshift. Watch meter.
6. You must see an increase in AC voltage or VSS is bad.
Old Aug 29, 2012 | 09:06 PM
  #57
halaferd's Avatar
halaferd
Ok, yeah that's the info I saw. The AC voltage setting is what threw me off and just wanted to be sure it wasn't a typo.
It's no secret I'm lackonh electrical knowledge, but it's doubled since being on here and "building" this truck.
Thank you, I'll report bk tomorrow with findings.
Old Oct 22, 2012 | 08:27 AM
  #58
F250F250F250's Avatar
F250F250F250
Here is a chart from the shop manual specifying E4OD pressures.
Old Oct 22, 2012 | 08:32 AM
  #59
halaferd's Avatar
halaferd
Awesome, I may try to look into getting a gauge and check it out. Thanks for the info!
speakerfritz
Jul 6, 2018 09:54 AM
underthebridgejim
Jan 31, 2016 07:14 PM
Blackwalls
Sep 4, 2008 11:50 PM
EdK
Oct 11, 2006 12:40 PM
PirateGhost
Apr 7, 2005 08:17 PM
