C6 flywheel
Old Oct 12, 2012 | 04:41 PM
Twistedwrench's Avatar
Twistedwrench
C6 flywheel
Mine is cracked anyone have the sheet metal drive plate ?
Rather get one off of here then from a junkyard .. If possible ?
Old Oct 12, 2012 | 04:42 PM
bashby's Avatar
bashby
Have you priced a new flex plate? What engine do you have?
Old Oct 12, 2012 | 04:44 PM
Twistedwrench
7.3 idi , as far as I can tell the flywheel or the drive plate aren't available new anymore ...
Old Oct 12, 2012 | 04:49 PM
bashby's Avatar
bashby
Rockauto has one for $166
Old Oct 12, 2012 | 05:12 PM
Twistedwrench
Thanks , I sent them an email as the parts illustration doesn't show the sheet metal drive plate .. :-(
Old Oct 12, 2012 | 05:26 PM
bashby's Avatar
bashby
Its under automatic transmission, then select flexplate. Z342 is the part #, made by ATP
Old Oct 12, 2012 | 05:32 PM
Twistedwrench
Yeah I found that . The problem is that there's also a sheet metal drive plate that is bolted over the flywheel that the torque converter bolts to . I'm not seeing the sheet metal plate ( which is what is cracked and I need )
Old Oct 12, 2012 | 10:28 PM
David85's Avatar
David85
Yup, you're right about the plate.
For anyone wondering, the C6 has a two piece setup with a cast iron flywheel and starter ring gear, and a separate stamped steel flexplate. Both pieces are held onto the crank with the same set of bolts.
Later E4OD style "flexplates" are a true flexplate that eliminates the cast iron flywheel. The stamped steel portion is made stronger while the flywheel is replaced with a spacer, and the starter ring gear is mig welded to the edge of the flexplate.
Later E4OD style "flexplates" have only the stamped steel flexplate that eliminates the cast iron flywheel. The stamped steel portion is stronger, the flywheel is replaced with a spacer, and the starter ring gear is mig welded to the edge of the flexplate.
I don't know if the E4OD style flexplate can work on a C6, but I was able to cheat the other way around with some minor modding.
My flexplate broke a while back but I was lucky and found a good C6 style flexplate that came off a 7.3 (think it was 1988). Paid a little too much at the wreckers but it was in decent shape.
Old Oct 13, 2012 | 06:01 PM
Twistedwrench
The bolt spacing on the e4od flex plate has six bolt holes for the toque converter . I suppose it could be redrilled to work ....
Old Oct 13, 2012 | 06:14 PM
Twistedwrench
Side note , a 1991 7.3 flex plate has 4 torque converter stud holes . I wonder if that will work ? I email ATP and inquired about the sheet metal drive plate ....we will see what happens .....
AHH HHA !!! I did a quick search and the newer one piece flex plate WILL work but I'll need a spacer that's used on the E4OD trucks ...! Anyone have a e4od spacer kicking around ?
Old Oct 13, 2012 | 08:40 PM
IDIDieselJohn's Avatar
IDIDieselJohn
And heres a pic I can add with your explanation.
Old Oct 13, 2012 | 09:15 PM
Twistedwrench
Yup that's what I'm going to swap mine over to.
Old Oct 14, 2012 | 02:11 PM
trackspeeder's Avatar
trackspeeder
There is a four hole version of the later stamped flexplate. 93 and up IDI
Six hole is for 95 and up PSD. This will not work on the IDI.
Old Oct 14, 2012 | 03:32 PM
Twistedwrench
Yeah I found that our last night ...
Old Oct 14, 2012 | 09:43 PM
David85's Avatar
David85
+1..........
