Hi guys, Im doing some re plumbing on my C4s cooling lines (adding an additional cooler and in line filter) and have a concern if a "AN" conversion fitting that uses a compression fitting as a transition from hard line to an is adequate to withstand the line pressure in the cooling lines. I have checked every site I could find, and in every case people seem to assume that the pressure at the test port, is the same as that of the cooling ports, which doesn't sound right to me. Is that fact, or fiction. I would appreciate it to no end to know what the max cooling line pressure is. My trans is a rebuilt 1970 C4 and has no issues. Thank you very much.
I can't tell you what the cooler line pressure is. I've only heard reference to " good flow". To check the trany pump pull the cooler line at the back of the case and check for " good flow" means the pump is working. I got this info from the ford transmission forum. Hope this helps and good luck with it.
Thank you for responding Bob, I guess I could always rig a temporary gauge in the cooling line since it's half apart anyway. Then I could tag it for the next guy. Take care .
It isn't right.
The test port is line pressure. The torque converter never sees line pressure, converter pressure is regulated to 120 PSI on later transmissions, I assume it's about the same in a C4, but I'm not certain.
The cooler circuit is a branch off the torque converter discharge. This pressure is lower than converter pressure. I would expect you would never see above 60 PSI in the cooler circuit.
Thank you Mark, it just didn't make sense to me. Im just a novice, and have only re built the one I have, but it sounded like a formula for disaster to me, besides bleeding off pressures from where they were designed to work. I usually hang out on the 48-60 forum, but very much enjoy the education I get by being a spectator over on this forum. "FTE Rocks"
