Boost Numbers
Old Aug 20, 2012 | 07:38 PM
mjonesjr's Avatar
mjonesjr
Boost Numbers
What kind of boost numbers are you all seeing with stock tuning?
This video shows what mine is making on stock sticks and tuning.
'97 F-350 7.3 Powerstroke Boost w/ Stock Tuning - YouTube
Old Aug 20, 2012 | 07:49 PM
Mdt1992's Avatar
Mdt1992
im got pretty much a similar setup minus the intercooler and e-fuel. stock tune i see around 16-17 or so max. chip turned up around 22 or so. i cant see the numbers on the video it was giving me a headache trying to read the vibrating numbers haha
edit: found out how to make it bigger, much easier on the eyes... thats close to mine in the stock tune
Old Aug 20, 2012 | 07:52 PM
95_Dually's Avatar
95_Dually
I assume it is easier to read when you are not holding a camera.
Old Aug 20, 2012 | 08:21 PM
glovemeister's Avatar
glovemeister
I got 120cc cali splits, with an 80 horse (50 actual) chip. With a 6637 and 4 inch exhaust, 3 inch dp. 3.55s, 5spd, and 35s the max I have hit is 28 max, although lately its been about 20 psi max. I hope efuel helps.
Old Aug 20, 2012 | 08:23 PM
glovemeister
My boost starts coming in really way too high so its not too usable for towing situations. I cruise about 1500-1700 at 60, and about 1900-2000 at 70. To get any real boost I've got to drop into 4th and hammer down and then it comes in great, but my egts get sky high even unloaded just pulling hills.
mjonesjr's Avatar
mjonesjr
With the old tunes and in the 80HP setting I could hit 28 PSI.
That video is stock tunes and stock 90cc sticks.
I think that is one benefit of having an auto. My boost comes in good and quick and doesn't drop out too bad during shifts.
Old Aug 20, 2012 | 08:40 PM
mjonesjr's Avatar
mjonesjr
Keep in mind that that is being measured on the cold side of the intercooler. I'd have to guess that my actual numbers right off the turbo would be 3-5 PSI higher than those numbers since the boost will drop across the intercooler.
Old Aug 20, 2012 | 10:50 PM
glovemeister
To address your earlier post. The only chance that I would have against an auto truck is a 40-50 roll. No way in heck I would shift my trans that quick for a drag race. Autos are far superior for being racers.
Mine is also measured with an IC.
I am impressed with your numbers though since I flow 30cc more fuel.
Old Aug 20, 2012 | 11:29 PM
bad12jr's Avatar
bad12jr
Need to install my ic but non it will make 17 or so. Tuned the 30lb boost gauge gets awfully close to zero on the wrong side if its really spinning.
Old Aug 21, 2012 | 12:20 AM
95_Dually's Avatar
95_Dually
I have the opinion of yes and no on the autos being superior. The auto has a disadvantage on the take off without a stall and the torque converter slippage doesn't apply all of the power to the ground until it is locked up. With the manual, you need to be quick on the stick but there isn't any power loss. Try a short throw shifter to quicken you gear changes. It makes a huge difference.
nossliw
43
Jul 15, 2012 12:13 PM
bigmacmonday
22
Feb 18, 2012 10:34 PM
wmiller
21
Mar 18, 2010 10:46 AM
honeyb
Apr 30, 2006 09:00 PM
basstardo
Jun 23, 2003 09:51 PM
