boost numbers with stage 2s?
Old Mar 15, 2010 | 12:52 PM
wmiller's Avatar
wmiller
What kind of numbers are you guys seeing with 2s and a d66? With out the chip i can only make about 17 and my hot tune around 25-27. Tony has my chip at the moment but numbers seem low to me. Up pipes aren't leaking. I haven't tried pressure testing the IC yet
Old Mar 15, 2010 | 04:02 PM
Welk49's Avatar
Welk49
If I push it 35+ Have heard the stories about the D66 not holding up, but knock on wood I haven't had a problem with it
Old Mar 16, 2010 | 01:22 AM
foxracing0934's Avatar
foxracing0934
without my chip in the truck I can hit 32-33 lbs on the highway really gettin into it. This is with 160/80's and a stock charger. With the chip that was tuned for stock injectors I could slap the 35 lb gauge in the face and she still pulled hard after that so I'm guessing 38-40.
Old Mar 16, 2010 | 05:55 PM
wmiller's Avatar
wmiller
mine would peg the 35* gauge with ease when I had a stock charger on it. I find it hard to believe that an IC and D66 would make that much diff. I'm pretty sure its a boost leak some where
Old Mar 16, 2010 | 06:36 PM
foxracing0934
Ya i find it hard to believe that a D66 is going to make you lose boost. I can see 2-4 lbs from the I/C but were is the rest going??? There is no way that D66 made you lose that much, I mean it is a still a stock charger. I'm going to guess boost leak aswell, might want to make up one of them fancey boost leak testers...
Old Mar 16, 2010 | 07:23 PM
427 fordman's Avatar
427 fordman
Sure wouldn't think you'd lose that much with an ic. I run one with just stage ones and hit 33 lbs.
Old Mar 16, 2010 | 10:07 PM
Talyn's Avatar
Talyn
D66 should hold up over 30 lbs from my understanding due to ball bearings instead of journals like the stock charger. Thus allowing you to go over the normal 30lbs you might dust it theory.
I'd really try to base the boost more on how well the truck is running.
Does it seem to run good? Just cause the boost numbers are low doesn't mean a lot.
Where is your boost sensor? In the spider, or in the MAP line?
Does somebody have a sensor like yours you can swap in to see if its just getting a bad reading?
If everything else is kosher, then You got a leak for sure.
Did you replace your Up Pipe doughnuts? Did you re torque them after a heat cycle or 2? They will leak when they are new after a good heat cycle.
If you have a scan gauge, see what the MAP sensor is saying for boost.
I'd put the boost sensor in the spider, IMO. Thats just me though.
If your airways for the IC are restricted, you will loose boost I think is how it goes. Takes longer for the air to get in there, so you loose the boost, so if something is screwed up.
Just thoughts here. =)
Old Mar 16, 2010 | 10:47 PM
foxracing0934
The Dominator 66 is not a ball bearing cartridge, it has the same center section as a stock charger so it is a journal bearing just like the stocker. I believe that the only difference is that the compressor wheel is larger, that information I don't remember 100% but I know that the center section is the same.
Old Mar 16, 2010 | 11:00 PM
Gobstopper909's Avatar
Gobstopper909
x2 what he said
Old Mar 16, 2010 | 11:11 PM
bruno2's Avatar
bruno2
Yes same center section different wheels and a bigger housing . My stg II's and a d66 will bump 30 + at wot .
Old Mar 17, 2010 | 08:52 AM
Talyn's Avatar
Talyn
Sorry guys. My bad on that one.
Looks like I wont ever buy a D66. haha.
Old Mar 17, 2010 | 09:20 AM
Neal 97 250's Avatar
Neal 97 250
a D66 is basically a stock turbo on steroids. It is a great turbo for use with stage I's but not really intended for stage II's. I can hit 40 psi with my II's and the D66 is not made for that pressure.
I would recommend H2e with II's.
Old Mar 17, 2010 | 01:48 PM
wmiller's Avatar
wmiller
Answers in red
Someone beat me to it but the D66 has stock style bearings but is a huge improvement over a stock charger
Truck runs good but feels laggy and doesnt feel like it has the boost
Boost line is in the spider
Its a mechanical gauge. Doubt its off but small chance
doughnuts and manifolds are new but never re torqued but don't have any soot around them
Scan gauge is in the mail
Thats the first thing on my list when i get it
Old Mar 17, 2010 | 05:39 PM
FARM69's Avatar
FARM69
I've hit 42 lbs a couple of times while hitting a pretty good grade at WOT with pedal left. I was more concerned about my EGTs so I backed off.
Old Mar 17, 2010 | 07:03 PM
bruno2's Avatar
bruno2
what is a hx50 turbo? Is it a ball bearing turbo? If so is it a drop in?
