Glowshift gauges
Old Aug 6, 2012 | 11:26 AM
truckrider814's Avatar
truckrider814
Glowshift gauges
I've searched the old threads and ain't found what I wanted. I'm wanting to get glowshifts diesels package of 3 gauges but I don't know if it comes with the wiring. And what's yalls opinion of that brand. I'm kinda tight on money and they seem to be best bang for my tight buck.
Old Aug 6, 2012 | 11:58 AM
DIYMechanic's Avatar
DIYMechanic
I believe they come with all the wiring you need, but they also sell a separate wiring kit that supposedly simplifies the installation. IIRC, it wasn't much extra to get the wiring kit. I think they are good entry level gauges. Heck Jim (Rosewood Diesel) sells them and runs them in his own trucks. That's what I will be getting when I get gauges. I'm somewhat in the same boat. I'm not cheap.... I'm just BROKE!
Old Aug 6, 2012 | 12:05 PM
thebig350's Avatar
thebig350
I got 'em, they're great. Install was a breeze and I have no complaints about them at this time. They come with all the plumbing you need for the job, and you shouldn't come up short on length. Like Nate said, they do sell a wiring kit, which probably makes it all a little neater looking if you are not in to wrapping your own wiring properly. I say bite the bullet and make the order.
Old Aug 6, 2012 | 12:17 PM
fordpride's Avatar
fordpride
This is the ones I have and they are under 200.
They have been in two years with out any issues
Sunpro CP7050 Light Truck Turbo Diesel Triple Gauge Kit:Amazon:Automotive
Old Aug 6, 2012 | 02:46 PM
ReBilld's Avatar
ReBilld
I got this one from Jim at Rosewood. $179 shipped to your door with everything you need to install. You can choose how you want the three gauges.
3in1 Diesel Combo Gauges
Old Aug 6, 2012 | 05:41 PM
dclack's Avatar
dclack
Don't get Glowshifts wiring kit. It's a waste of money. It's made for wiring up the sensors, but the boost gauge doesn't have a sensor and uses tubing and the egt sensor comes with plenty of steel braided wire. The only one that need wiring for me was the fuel pressure gauge.
Old Aug 6, 2012 | 05:56 PM
Mdt1992's Avatar
Mdt1992
I have the boost and transmission temp glow shift on my a piller. I didn't get the triple pod kit since I already had the digital egt gauge. I made my harness simple install and havent had any ptobloms
Old Aug 7, 2012 | 02:52 PM
truckrider814
Well bit the bullet bought their package deal pillar pod plus three gauges for 216 free shipping not bad just can't wait for it to get here.
Old Aug 8, 2012 | 12:32 AM
drpaul311's Avatar
drpaul311
I have a 1996 with a 7.3L. i just bought my triple gauge / pod set. where did you put the transmission sensor? in the directions, it states to locate the test port on the tranny. where is it located?
as for the other guy asking about the additional wiring, i think additional wire really isnt necessary. i wouldnt spend the extra money for it. but these glow shift gauges are pretty sharp.
Old Aug 8, 2012 | 10:10 PM
drpaul311's Avatar
drpaul311
if you dont mind, where did you install your temperature sending unit for the transmission temp gauge? im now installing my gauges in my truck.
Old Aug 8, 2012 | 10:14 PM
Mdt1992's Avatar
Mdt1992
in the side of the transmission drivers side right above the pan towards the front remove the 7/16" pipe plug and thread in the sensor
Old Aug 8, 2012 | 10:26 PM
drpaul311's Avatar
drpaul311
thank you sir. i got it. i appreciate it. these gauges have been so much easier than i first had thought.
Old Aug 8, 2012 | 10:44 PM
Mdt1992's Avatar
Mdt1992
no problem. reallly is a simple install hardest part is trying to get the gauges to sit where you think is straight up and down in the pod! .
Old Aug 9, 2012 | 12:36 AM
drpaul311's Avatar
drpaul311
i agree! ive got the intake off and drilled. i just need to tap it. then my boost is hooked up and working. and i need to drill my exhaust pipe and tap it and it will be up and working. not a difficult addition!
thanks again for your help.
Old Aug 9, 2012 | 09:39 AM
85F250Diesel's Avatar
85F250Diesel
Make sure you put the EGT probe in the manifold, not the exhaust pipe!!! If you get your temps after the turbo, you're just guessing, really. Specs from International and Ford state that max manifold ext temp should not exceed 1250 F. After flowing through the turbo, the gases are cooler, but there is no way to know how much cooler. It's a no brainer, really. Put your probe before the turbo.
