Hey everyone. What would be a normal amount of boost on a stock truck? All I got so far for performance mods is a DIY intake and an old superchips tune. Exhaust and dp is on its way but that is all stock at the moment.
I max out at like 15psi.
I have stock stocks, 6637 intake, PHP tunes, and a 3in dp to 5 inch exhaust. Also have the banks quick spool housing. What kind of boost should i be seeing? I have leaky up pipes so i max at 10 psi, but itd be nice to have a ballpark
I can reach 22psi with stock sticks and the mods in my signature.
So from what im seeing, unless my superchips max tuner sucks, when i put my exhaust and dp on i should see at least a 5psi increase in boost... If I don't then my turbo needs a rebuild or i got bad injectors. Am I correct?
Or you have an exhaust leak between the exhaust manifolds and turbo.
