Sponsored by: Real Truck
Fuel filter disaster
Old Aug 14, 2012 | 06:13 PM
DieselVol's Avatar
DieselVol
Fuel filter changed last week. Had to take the top off of the upper filter today and now can't get it to go back on without leaking (proper, blowing diesel everywhere when the key is turned). Any tips on how to get the o-ring to reseat? As I tighten, a small amount will poke out and that's the leak point.
Old Aug 14, 2012 | 06:18 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Did you use a new o-ring?
Josh
Old Aug 14, 2012 | 06:24 PM
DieselVol's Avatar
DieselVol
Josh
Yes last week, no now. Can you just buy an o-ring at autozone? Also, it says 14Nm on top. I don't have a torque wrench, so is that finger tight, not pulling too hard tight, what? Last week just popped it on no problem. O-ring does seem loose.
Old Aug 14, 2012 | 06:44 PM
Bullitt390's Avatar
Bullitt390
O-ring should be pretty tight.
14nm = about 10~11 foot lbs. I snug the cap down and then give it a little nudge to tighten it. No need to be the incredible Hulk.
Josh
Old Aug 14, 2012 | 07:01 PM
DieselVol's Avatar
DieselVol
Josh
Should the o-ring be all the way at the top of the cap, as in it can go no higher up?
Old Aug 14, 2012 | 07:09 PM
Bullitt390's Avatar
Bullitt390
Guess I don't really pay attention, but I think the o-ring can only really go in one groove on the cap.
Is this a 7.3 or 6.0/6.4 you're working on?
Josh
Old Aug 14, 2012 | 07:16 PM
senix's Avatar
senix
also lubricate with clean engine oil
Old Aug 14, 2012 | 07:19 PM
DieselVol's Avatar
DieselVol
Josh
6.0, I think the old ring got pinched and is loose. Got a replacement at AZ that I'm putting on now. Stay tuned.
Old Aug 14, 2012 | 08:28 PM
DieselVol's Avatar
DieselVol
Autozone generic o-ring worked great. No leak. For the record, the o-ring does not go all the way to the top. There is a small groove it rests in below that. Thanks for the help.
Old Aug 14, 2012 | 11:02 PM
Lubbockguy1979's Avatar
Lubbockguy1979
I've never use a tq wrench. Tighten it till the cap is against the aluminum. Then make it snug. Or 1/16-1/8 turn. iirc
Old Aug 15, 2012 | 09:58 AM
DieselVol's Avatar
DieselVol
Since my engine took a diesel bath last night, my EGTs are down about 100F. I assume this will improve as all that diesel burns off?
dusfou
21
Jan 21, 2010 04:19 PM
crazymut
Jan 1, 2010 11:51 AM
chi6488
6.4L Power Stroke Diesel
Sep 28, 2009 04:15 PM
7.3blacksmoke
Jul 20, 2007 12:12 AM
Dwid
Nov 6, 2006 09:43 PM
