Sponsored by: Real Truck
CD Error-Disc Stuck
Old Aug 13, 2012 | 01:56 PM
Big Sky's Avatar
Big Sky
CD Error-Disc Stuck
My CD 6 has been giving me the CD Error. One of the discs is stuck right where it goes in the slot. In the past I would just thump the dahs and it would work. If I can't get it to work, how do I remove the discs?
Old Aug 13, 2012 | 06:04 PM
IslandBlueV10's Avatar
IslandBlueV10
This is a common problem, I finally just got rid of mine. First try pulling the fuse for the radio for a second, then put it back in. Mine then would sometime eject the cd. If that doesn't work you will just have to pull the radio and take it apart to get cd. After that start looking at replacing the radio.
Old Aug 13, 2012 | 06:07 PM
kameronth's Avatar
kameronth
If it's stuck right where it goes in I have seen people use tweezers to pull it out but it will ruin the CD. That will usually happen due to a slick surface on the CD. If it's stuck inside it will need to be cracked open.
Old Aug 13, 2012 | 06:41 PM
madsonp's Avatar
madsonp
Hey, I see you're from Billings, me too. There's not many of us on here. Sorry though I can't help with your problem, I just wanted to say hi.
Old Aug 13, 2012 | 07:05 PM
SuperDutyScaler's Avatar
SuperDutyScaler
my single cd on my 2004 did that, i tried pulling the fuse etc and nothing would work. I pulled it out and pulled the radio apart only to find the radio had scratched the cd all up, i then fixed the radio with a BFH and bought a Sony head unit
Old Aug 14, 2012 | 10:41 AM
Big Sky's Avatar
Big Sky
Hi back to you. Nice rig!
Old Aug 14, 2012 | 11:16 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I have had a few Ford radios do that. I was able to use a butter knife through the slot to help the disc out. It didn't ruin the disc, either. It seemed each time that the disc need to move up about the thickness of the knife and them it came out normally.
Old Aug 14, 2012 | 01:00 PM
BCM's Avatar
BCM
Same here... I don't remember if I had to put the knife on top of the CD or below it, but raising (or lowering) just a bit let it eject. I found it happened with CDs I burned myself mostly in the beginning. Then it started doing it for all and I finally started plugging my iPod into the entertainment system and listening to my stuff that way... Until I sadly sold the Expedition.
stickthrower
Nov 16, 2024 05:43 PM
Whitey Ford
Jan 15, 2013 12:23 PM
MeanGene427
Mar 20, 2009 11:56 PM
smoore79
Oct 22, 2008 02:32 PM
bri687
Aug 20, 2007 12:28 AM
