Sponsored by: Real Truck
Rough idle
Old Aug 13, 2012 | 09:44 AM
Dezrider's Avatar
Dezrider
Rough idle
This started about a month ago. I would start the truck and it would idle rough for a minute then smooth out, now it doesn't smooth out any more. Yesterday I checked the coils and they were all firing, I put a new air filter in and cleaned the MAF sensor, replaced the PCV and nothing helped. It's a F-250 V-10 with about 230,000 miles. Any ideas?
Old Aug 13, 2012 | 10:01 AM
Druffing9590's Avatar
Druffing9590
Rough idle
Dezrider i had the same problem with my 5.4l and it got worse and worse every week. But that was the cat. Now im having that problem on my other truck but its not getting worse just when i start it up in the mornings then goes away.
No idea whats causing the problem. If i figure it out i will update.
Old Aug 13, 2012 | 11:56 AM
Dezrider's Avatar
Dezrider
I was thinking it might be a plugged Catalytic converter but I don't know the symptoms and how to check it
Old Aug 13, 2012 | 12:00 PM
Druffing9590
rough idle
The only way to know for sure is to replace the cat cause they I'm pretty sure there isn't o2 sensors to throw a check light.
Old Aug 13, 2012 | 01:19 PM
Rick03F250's Avatar
Rick03F250
The way I was told to check my cat, was to take out the o2 sensors and start it, if you get more exhaust from the open holes than out of your tailpipe, it's most likely plugged.
Drive it for a short while up a steep grade to see if you gain power and that will tell you.
Upon inspection, I had one of the ribs break apart and completly plug the ones behind it.
Old Aug 13, 2012 | 08:03 PM
Dezrider's Avatar
Dezrider
Driving down the freeway today with the AC on the truck was pinging a little, almost felt like I was towing my boat or something. could a plugged Cat. do this? It doesn't feel the same as when one of the coils was bad. Fuel injector problem?
Old Aug 13, 2012 | 11:58 PM
jerem0621's Avatar
jerem0621
Sure sounds like a cat to me. If it plugs up 100% you will know because it will blow the little pipes off the dpef.
Old Aug 14, 2012 | 05:24 AM
Druffing9590
That's what happend to my one truck. It started out like that and got worse. I think its time to have the cat replaced before you have to have it towed. My truck got to a point I couldnt get over 25mph. I'm prolly going to have my mine replaced on my other truck now then.
Old Aug 14, 2012 | 06:51 AM
kbsupercrew's Avatar
kbsupercrew
I would try cleaning the IAC, and the throttle body
Old Aug 14, 2012 | 01:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
To test the cat, you disconnect the exhaust ahead of the cat and take a test drive.
Old Aug 14, 2012 | 01:18 PM
redford's Avatar
redford
If this is a 2V engine, clean or replace the IAC.
David Bender
Dec 27, 2014 12:51 AM
neilr
Escape & Escape Hybrid
24
Oct 11, 2011 04:16 PM
2001supercrewf150
Modular V8 (4.6L, 5.4L)
Mar 25, 2010 04:23 PM
JoeKramer
Mar 1, 2005 01:37 AM
smasher0219
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 11, 2004 11:43 AM
