((removing starter))
Old Aug 13, 2012 | 08:42 AM
billb2000's Avatar
billb2000
well I need to remove my starter out of a 47 truck,it needs to be rebuilt,it is a flathead ,is there any tricks or any thing I need to know to pull it out ,and to put it back in ,thanks !!
Old Aug 13, 2012 | 09:04 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Having never removed a starter before in my life, but figuring it wouldn't be too hard, I decided to go for it. Didn't turn out too bad at all. No magic required.
Old Aug 13, 2012 | 11:39 AM
billb2000's Avatar
billb2000
thanks bmoran4 ,I will give it a shot!!!!!!!!!!!!
Old Aug 13, 2012 | 12:16 PM
r_reed's Avatar
r_reed
i assume it's the same as a 49. one precaution, besides unhooking the electrical cable, there are two long thin bolts that go all the way through the starter. they hold it to the starter plate and hold the starter together. there is (or should be) a bracket at the end of the starter that braces it to the oil pan, one of the long bolts goes through it. when you get the long bolts loose, it's usually a good idea to try to get it out in one piece and add a nut on the end of the long bolts so it doesn't fall apart. may not matter if you are going in for a rebuild anyway.
Old Aug 13, 2012 | 12:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You usually have to angle the starter to clear the ring gear, because the drive is actually behind the ring gear.
Old Aug 13, 2012 | 05:58 PM
bobj49f2's Avatar
bobj49f2
If the starter falls apart when you pull it out it's no big as long as you're going to have it rebuilt.
The trick is when you are reassembling it, if you're the one doing the work. My dad showed me many, many years ago how to put them together. First, pull the brush springs out and rest them on the outside of the starter case. Use a hook of some type, my dad used to use an old shoe button hook (How many of you know what I'm talking about?)The springs are rolled coil type springs and one end will be anchored in the starter so don't remove the entire spring, just the end that contacts and holds in the brush. Also, keep the brushes out of their sockets. Slide in the armature and once it seated insert the brushes and the retaining springs. You will never get the armature to seat without doing this, or at least it will be a lot more frustrating.
Old Aug 13, 2012 | 09:49 PM
abe's Avatar
abe
I do but not because I am that old, because my parents collected anticques and had some laying around...
schoo
1947 and Older Ford Trucks
Sep 11, 2012 07:05 PM
twise
May 21, 2009 02:26 PM
mojoman
32
Dec 2, 2008 08:10 AM
e-tek
Jun 7, 2008 10:51 AM
etnies13
Jul 14, 2006 08:43 AM
