Wiring up a Flatbed
Old 08-10-2012, 02:46 AM
Kennetho's Avatar
Kennetho
Kennetho is offline
Question Wiring up a Flatbed
Where do you guys tie into for your flatbed running lights? I have 8 clearance lights, 2 on each corner, and a 3 bulb ID in the back.
Do you just tie into the tail light wires? The stock park light wires look like they are about 16 gauge. Was thinking I could maybe just wire 1/2 to each side to spread the load out on the wires. They are single bulb style and the ID is an led so the load shouldn't be to bad.
Currently they are just tied into the trailer wire since I'm not towing atm. Seems to do ok, so I would assume the tail light wires would be ok with only 4 running on each.
Also, whats the wiring for the 7 blade trailer plug? I got 7 wires that the previous owner cut.
07 F350 C&C
Thanks, Kenny.
Old 08-10-2012, 10:06 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,135 Likes on 1,031 Posts
https://www.ford-trucks.com/forums/5...6-11-12-a.html
Go here for the in fo on the 7-way. Lots of good info on trailers/truck stuff there.
Old 08-10-2012, 11:36 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,726 Likes on 1,396 Posts
You should be ok with your wiring plans, especially since you said you are going to use led's. I don't know about the later trucks, but the early ones(80 thru mid 90's) had trouble with overloading the running light wiring at the headlight switch. Maybe they fixed that on the later trucks.
Mason_72_F100
06-18-2019 08:03 AM
chooch07
1999 to 2016 Super Duty
10-15-2013 07:12 PM
FordNFishinLover
04-23-2010 08:21 PM
74crewcabshortbed
07-25-2007 08:42 PM
binny
Electrical Systems/Wiring
04-12-2007 05:46 PM
Quick Reply: Wiring up a Flatbed
