Is there a difference between 360/390 dist.
Aug 9, 2012 | 04:47 PM
Is there a difference between the 360 fe dizzy and the 390 dizzy thanks!
Aug 9, 2012 | 05:23 PM
The 360 is the ugly twin sister of the 390. One boob sags lower than the other, but other than that, identical twins.
John
Aug 9, 2012 | 06:07 PM
There might be some small differences in calibration but they will interchange.
Aug 9, 2012 | 06:15 PM
Ok thanks, was told by PO it was a 360 ran vin off fordiacation looks like a have a 390. Did'n think there was a difference, replaced my awhile ago been having a starting issue.
John if you read this could you double check (vin on other post) my vin I read were you said there not always correct with there vin table. Thanks.
Aug 9, 2012 | 07:20 PM
The 4th digit of the VIN is the engine code. 1968/76 F100/350: H = 390 2V / M = 390 4V (1974/76) / Y = 360 (all are 2V's).
1968/76 F100/250 4WD: The only available V8 engine was the 360.
Aug 9, 2012 | 07:32 PM
Quote:
Originally Posted by
NumberDummy
Here is the number F10HCG60283
If possible I think it was ordered with a 390 opition.
Aug 9, 2012 | 07:44 PM
70-360fe
It was ordered with 390 option.
See your other thread, I decoded your VIN and the Warranty Plate codes.
Aug 11, 2012 | 08:23 AM
NumberDummy
Got it thanks, looks like I've been upgraded to a 390.
SuperBeaner
Oct 20, 2008 06:52 PM
72ford250
Jul 6, 2005 07:51 AM
horns1969
Sep 22, 2004 04:30 PM
boomer202
Jan 1, 2004 04:39 AM
HBINGER1
Jan 7, 2003 06:13 PM
