IP change tools
Old Aug 8, 2012 | 12:01 AM
bduemig's Avatar
bduemig
IP change tools
I am going to be changing my IP and injectors soon. I have seen that I need a 12 point socket and a cut off wrench.
What size 12 point socket is needed and what size and how long do I make the wrench?
Old Aug 8, 2012 | 01:06 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Not sure what the 12 point socket is for. The injectors are 6 point. I don't recall the size. For the IP. It is possible to get to all three nuts with some 9/16th combo wrenches, but It is a lot easier to do it if you make one. Here are some pix of mine.
Name:  IP wrench.jpg
Name:  IP wrench profile.jpg
The length is not as important as the bend and the grinding. I can get to all three nuts with this wrench without removing anything from the motor at all. It makes timing adjustments a breeze. Now is a good time to test and replace GP's too.
Good luck,
Mac.
Old Aug 8, 2012 | 07:09 AM
bduemig's Avatar
bduemig
Thanks for the reply. Could the 12 point socket be for the three bolts on the timing gear?
Also my glow plugs were changed by PO just before I bought the truck. only 10K on them!
Old Aug 8, 2012 | 09:50 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
yeah. when you take that little access cover off of the front of the oil fill case you will need the 12 point 5/16"
Old Aug 9, 2012 | 12:05 AM
akamacgyver
Clueless spectator!
Oh yeah, forgot about them little buggers, and I just pulled my pump about 4 days ago!
Firefighter 1406
61
Nov 12, 2015 10:25 PM
queen of spades
15
Oct 6, 2013 11:41 PM
YardPig
15
Aug 16, 2013 12:16 PM
flbmcman
23
Dec 7, 2012 07:19 AM
Wookie35
Feb 26, 2009 09:29 PM
