IP and Injectors
^^ lol is there even a difference between the 7.3 and 6.9 pump?
And Quintin, contact me on FB or msn, I think i'm gonna need that pump, the pump on my van is severely worn now, to the point I can't even shut the engine off at all anymore once warmed up, even if I pour water on the pump, she won't re-start.
the head and rotor sets are different. some 6.9 pumps have different housings. When doing a mild performance build the 7.3 pump is better.
the only difference between an N/A 7.3 pump and turbo 7.3 pump is the torque screw, which is absolutely worthless, and the advance piston is a little different. Output capability is the same.
on
92-94 7.3l n/a ip's also have the torque screw.
all of these,turbo or not,have the screw:
DB2831-5013 05013 1816521C91 7.3 Liter 1992-1/2 Ford F Truck - Auto Trans. (185 HP)
DB2831-5027 05027 1816522C91 7.3 Liter 1992-1/2 Ford F Truck - Auto Trans. (170 HP)
DB2831-5028 05028 1816523C91 7.3 Liter 1992-1/2 Ford F Truck - Man Trans. (185 HP)
DB2831-5029 05029 1816524C91 7.3 Liter 1992-1/2 Ford F Truck - Man Trans. (166 HP)
DB2831-5030 05030 1813460C93 7.3 Liter 1992-1/2 Navistar S Series Truck (170 HP)
DB2831-5031 05031 1813465C93 7.3 Liter 1992-1/2 Navistar S Series Truck (155 HP)
DB2831-5032 05032 1816625C92 7.3 Liter 1992-1/2 NATO/Runway Sweeper (155 HP)
DB2831-5069 05069 1816340C91 7.3 Liter 1993-94 Ford F Truck - (Turbo) Auto Trans. (190 HP)
DB2831-5070 05070 1816350C91 7.3 Liter 1993-94 Ford F Truck - (Turbo) Man Trans. (190 HP)
funny,first time i noticed the chart error.it should be reading 1992-94 1/2 instead of 1992-1/2 for the n/a ips.
Regardless, aune does the pump have the external fuel curve screw? aka torque screw.. i know youre not super far from me so shipping shouldnt be to bad, PM if you come up with a price.
you yourself told me the turbo pumps have bigger plungers, and also are able to deliver slightly more fuel.
different...now im wondering lol
The 7.3 pumps are supposedly all .31" plunger pumps, Turbo or not...
The 6.9 pumps are supposedly all .29" plunger pumps...
This would make sense on why my IFS N/A 7.3 pump performs on par with my old Turbo Cal... Though the Turbo Cal does have a slightly different timing curve, I could feel the difference, little more *** in the mid-range.
However, I do have a pump that looks (Or looked, Its torn down now) completely stock, right down to the tie-wired gov rod and stanadyne tag, in a plugged Torque screw housing, that is a DB2829-4746, and confirmed .29" Pump... Came off of a dead stock looking 7.3. Not saying its the rule, but its definately an exception...
toddpyles33
01-28-2012 03:58 PM
