won't start
Old Aug 9, 2012 | 02:39 AM
Yahiko's Avatar
Yahiko
Is the gauge a bit off ?
If it is jumping all over the place or mid way through a tank it go
to full. Then it may be time to have the sender checked. They are spendy
buggers. Or it could just be a leaking seal at the pickup to tube in the tank
and that is not a hard fix. You just don't want to run out of fuel very often
it will kill injectors. You can some times see a bad sender with a high level
scan tool that is a bit more than the ones they have at Autozone. What you
looking for is sender errors. I am running with a bad sender right now. What
I do is go by miles driven and I know what my MPG should be most times.
The only time I get a bit off is when I am running empty on the freeway for
long trips and I get better a better MPG.
Sean
Old Aug 9, 2012 | 03:48 AM
bismic's Avatar
bismic
Running out of fuel (even low fuel pressure) can be hard on injectors, and they are expensive if you have to replace them.
Big Joe Walker
Jun 8, 2017 02:54 AM
tr0y
Mar 17, 2013 05:51 PM
rdtbhw
Feb 27, 2008 12:23 PM
FORDSDOWNER
Oct 4, 2007 08:37 PM
Belindagw
Mar 8, 2007 09:00 PM
