97 with electrical problems, driver side engine not running more inside
Old Aug 5, 2012 | 03:47 PM
keiser blade's Avatar
keiser blade
its a 97 with 170k. the driver side engine bank is not running, i replaced the uvc, idm the driver module is from a 2000 model its the black one. and number 8 injector solenoid. the code scanner said no 8 injector voltage problem, the engine runs fine with the number 8 injector unplugged.
Old Aug 5, 2012 | 11:39 PM
farmert's Avatar
farmert
Did you check the pins in the valve cover gasket, and the plug to the gasket to see if the #8 was burned? The IDM will shut one bank off to protect itself if there is a problem.
Old Aug 6, 2012 | 07:00 AM
DIYMechanic's Avatar
DIYMechanic
Ohm the #8 injector solenoid through the wiring on the VC. You're looking for right around 3.8 ohms. If you don't get anything through the VC, then ohm the injector by itself. That will tell you if you have a bad injector solenoid or if it is a wiring issue.
And yes, the IDM will shut down a whole bank of cylinders if it senses a bad short on one injector.
Old Aug 6, 2012 | 05:48 PM
keiser blade
Smile fixed with details
ok guys ill explain what i found.
first off the idm failed which shut down the driver bank of the truck.
i started out changing the valve cover gasket and the electronics.
it still had the number 8 cyl jacked up.
so today i took off the engine harness after getting 100.0 through the injector harness on number 8 cyl, the wire harness was ok, i got down to the valve cover plugs on the inside of the head, the new valve cover conection harness had the number 8 injector wire (pink/yellow) going to the glow plug, and the glow plug wire goin to the injector.
So needless to say the assembled the uvc incorrectly.
the truck runs better then ever with the 2000 injector module now.
thanks everyone
Brandon
Old Aug 7, 2012 | 05:53 AM
DIYMechanic
Nice! Guess that goes to show us all that you can't necessarily assume that new parts aren't necessarily GOOD parts...
Old Aug 7, 2012 | 08:38 AM
madpogue's Avatar
madpogue
Wait, don't tell us -- Dorman?
Old Aug 9, 2012 | 09:18 PM
keiser blade
Yep doorman, I knew I should a went with ford lol, that's correct new parts aren't always good. Thanks again
Old Aug 10, 2012 | 02:31 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Hmm...I've always had good experiences with Doorman products. Hit and miss i guess
Old Aug 10, 2012 | 10:21 PM
fordman67's Avatar
fordman67
Yea,seems like when they are good,they are good.but when they are bad.they are terrible....kinda like the s10 clutch slave i installed today...bleeder in wrong place...pointing at the side of the trans rather than outside by the line like oe.
Furniture Doctor
May 8, 2016 10:25 PM
j1msevier
Mar 6, 2013 06:14 PM
rehpig
Nov 30, 2011 05:04 PM
bigbadwolfe
Mar 11, 2007 05:56 AM
skibum0101
Oct 31, 2006 06:36 PM
