95 7.3 PSD, what appears to be a pressure sensor or switch located it the center of the valley, behind the fuel filter, with single wire. It is leaking diesel fuel. Whats it called?
Jim I thought that was the fuel restriction sensor ?
95-96 had the Water In Fuel Sensor in that location. 96-97 it was relocated on drivers side bottom. From top to bottom "Fuel Restriction Sensor", "Fuel Heater Connector" and "Water In Fuel Sensor".
Ford or International. International is always a lot cheaper. Many just remove the sensor and plug it up with a fitting, don't know the size off hand though.
Jim are you sure on that?, because IIRC the fuel restriction sensor is what was relocated
Pic of the early and late canisters. the "Fuel Heater Connector" and "Water In Fuel Sensor" in the drivers side of the canister are in the same position in both models.
"Fuel Filter Restriction Sensor" or "Fuel Filter Vacuum Sensor"
Ford part #E8TZ-9S283-A
IH 1809435C1
Mike, I can tell you for a fact the brain goes first, fortunately other parts still work.
Jose, I'm in rep jail but thanks for those very informative pictures.
I took it to International and they matched it up visually. It wasnt the leak. The fuel pump was leaking out of the weap hole and spraying up onto the sensor. Sure looked like it was leaking. It was $38 at IH dealer FYI, whatever it was. Thanks for all the help.
