Driver power window
Old Aug 4, 2012 | 03:21 PM
SlashinSuzyQ's Avatar
SlashinSuzyQ
Angry Driver power window
I'm a newly single parent to four girls, so please keep this in mind when responding as I am doing this myself and do not have a lot of money.
My window messed up this past week and I was able to get it up (and keep it there) until this weekend (today) so that I could fix it. Removed door panel and what nots to view the enternals of it. There's a "****" on the end of the arm (sorry, I don't know all the proper names) that slides back and forth on a track. The **** came out of the piece that it sits in, that slides in the track.
How in the heck do I get this dang **** back into the hole. It seems almost impossible.
Thanks for any help in advance.
Old Aug 4, 2012 | 04:54 PM
RedHorse1's Avatar
RedHorse1
It kind of sounds like the regulator has failed. You don't say what year Expe this is so "****" and "arm" may be something else than what I'm envisioning.
Take a look at this post. "Yardbird" posted an excellent how-to in '08 detailing the replacement of the window regulator. I've done both front doors in mine and it's pretty straight forward. Getting the door skin off may be the most complicated part.
https://www.ford-trucks.com/forums/7...regulator.html
Good Luck!
Old Aug 4, 2012 | 07:04 PM
SlashinSuzyQ
My apologies, it's a 98 Navigator 5.4 2x2.
I read through the post you supplied (thank you so much by the way). However, it seems as if you have to replace the ENTIRE thing?? I surely hope not, although it wouldn't surprise me if this is the case.
Old Aug 4, 2012 | 10:04 PM
Boat Tug's Avatar
Boat Tug
Only about $70 on Amazon for the whole thing.
Old Aug 5, 2012 | 05:40 PM
SlashinSuzyQ
Yes, thank you. I did check on prices for the entire piece, but I would like to just get the **** back in place seeing as how that's all that is wrong...does anyone know if this is possible?? Not to sound like a tight wad, but $70 could be new shoes for my girls before school starts back.
Old Aug 6, 2012 | 03:23 AM
alloro's Avatar
alloro
Anything is possible depending on your skill level and the tools at hand. The roller (or **** as you call it) is held in place by a pressed in rivet. It is not something that can simply be reinserted and expect to remain in place. You would have to roll the edges over after getting it back where it belongs. To do this you will also have to remove the entire regulator assembly. I get the whole pair of shoes deal, but sometimes things do break and have to be replaced.
Old Aug 6, 2012 | 09:04 AM
RedHorse1's Avatar
RedHorse1
If it's come apart I would expect the cables to have unwound and getting them back in their proper place could be a challenge.
Old Aug 6, 2012 | 10:12 AM
alloro's Avatar
alloro
If her profile is acurate, then she has a 98 Navigator so there are no cables, just tracks and a lift arm. I think it wasn't until 2003 that the regulator was redesigned using cables.
Old Aug 6, 2012 | 10:29 AM
expydaddy's Avatar
expydaddy
If your motor is still working, then you just need the regulator. Be VERY CAREFUL when you switch the motor to the new regulator as it is under tension and will swing back and embed itself somewhere on your hand. I found this out the hard way!(3 stitches).
You might also need new glue for the supports that hold the window in place.
While the door card is off, check the condition of the bottom of the door for rust, etc. Spray some rust converter on it if it is rusty.
If the regulator is riveted in you will need to drill them out. Replace with t-10 (?) screws.
Good luck. There is an awesome write up on this on you tube under 1aauto.
Old Aug 27, 2012 | 11:25 AM
gardengirls's Avatar
gardengirls
Not sure if you have fixed this or not. I also have 4 daughters and have yet to make a repair I needed back in the spring.
I also have this problem. I have a 98 expy so the part should be the same. You can buy just the regulator for about $30. I haven't repaired mine yet, but I have also heard that you need to take precautions when removing the motor from the old regulator or it will snap back on your hand and cause some pretty bad damage. Someone suggested using clamps. Also I have read about a 2 part epoxy and a 3m brand adhesive are best to reglue the glass.
Good Luck!
breadstick
1997 - 2003 F150
Feb 22, 2024 12:15 AM
Hurtin Albertan
15
Jun 5, 2015 06:10 PM
mozzles
Sep 15, 2012 08:53 PM
MrRogers
Aug 4, 2009 09:54 PM
Scruffy
Apr 20, 2009 05:08 AM
