Idles funny
Old Jul 27, 2012 | 09:12 PM
ReBilld's Avatar
ReBilld
Idles funny
'97 F250 PSD, after it's up to normal operating temp, and I stop and let it idle, it idles up and down just a little. It's fluctuating at about 1 to 2 sec. intervals. When it's up, it's smooth. When it drops down, the truck rocks. Just changed the CPS, but it was doing it before. Did injector o-rings a couple months ago. What would cause this? Would the HPX crossover help this, or is it an IPR or oil issue?
Old Jul 27, 2012 | 09:22 PM
85F250Diesel's Avatar
85F250Diesel
FPR screen?
Old Jul 27, 2012 | 09:26 PM
ReBilld's Avatar
ReBilld
Originally Posted by 85F250Diesel
FPR screen?
I just changed the fuel pump, hoses and put all new o-rings in the fuel bowl and FPR. Had the FPR apart and cleaned it. That was around the same time I did the injector o-rings.
Old Jul 27, 2012 | 09:52 PM
fordman67's Avatar
fordman67
When u find it.let me know.mine does the same thing.not as much in gear though.i have auto.
Old Jul 27, 2012 | 09:56 PM
fordpride's Avatar
fordpride
Bill unplug the icp and see if it clears up
Old Jul 27, 2012 | 09:59 PM
ReBilld's Avatar
ReBilld
OK, I'll try it in the morning.
Old Jul 27, 2012 | 10:01 PM
fordpride's Avatar
fordpride
Look for oil in the plug too.
You have another PSD huh? You could just swap ICP's
Old Jul 27, 2012 | 10:05 PM
ReBilld's Avatar
ReBilld
Yeah, I have two, a 94.5 and another '97. That's where I got the CPS! LOL! It's a grey parts store one though. I need to get off my butt and get one from Ford!
Old Jul 28, 2012 | 09:26 AM
ReBilld's Avatar
ReBilld
Unplugged the ICP and it smoothed out. No oil in the plug that I could see. I'll look closer when I change it.
Thanks Mike!
Old Jul 28, 2012 | 09:49 AM
fordpride's Avatar
fordpride
Now plug it back in and see if it come back. If it doesn't try to wiggle the plug around to see if it does
Old Jul 28, 2012 | 10:34 AM
blageurt's Avatar
blageurt
When I changed my ICP it really improved my idle AND throttle response.... It was working and not leaking, but it looked original ( 400K) and I had an International one handy, that I paid 75 bucks for from a buddy who worked at the local dealer .......
Old Jul 28, 2012 | 04:40 PM
ReBilld's Avatar
ReBilld
I plugged it back up right after I unplugged it and the idle smoothed out. The up/down idle didn't come back and I didn't wiggle it or anything. I'll try it again tomorrow. I'll take the truck out and get it up to temp and see what it does.
Old Aug 10, 2012 | 11:09 PM
ReBilld's Avatar
ReBilld
The up and down idle issue came back when I plugged the ICP back up. I had it unplugged for 30 sec. or so. While it was unplugged the idle smoothed out. When I plugged it back up, the idle issue came right back. I took the ICP from another truck and put it in mine, no change. That one may be bad too, or is it something else?
Old Aug 10, 2012 | 11:42 PM
fordpride's Avatar
fordpride
SURGE AT IDLE
1. ICP circuit problem, disconnect the ICP sensor, if the surge goes away then you possibly have a bad ICP sensor.
2. AA code injectors installed into a engine that require AB code injectors will cause a surge (California emissions in 96 and 97 require AB injectors)
3. 94-97; if you have any transmission range sensor codes repair these first. A bad transmission range sensor can back
See if it surges in neutral
Old Aug 11, 2012 | 08:47 AM
ReBilld's Avatar
ReBilld
SURGE AT IDLE
Thanks again bud
JIMRSX
Jun 8, 2019 12:08 PM
hawkco66
Apr 26, 2017 07:18 AM
gearhead351
Apr 30, 2012 08:38 AM
teederj2002
Apr 4, 2007 12:21 PM
camdaddy
Mar 25, 2005 03:30 PM
