I was thinking it was on the passenger side, but I couldn't remember. I remember it goes on a stud with a nut on it and mine the stud wanted to back out instead of the nut coming off...
Ummm, what's left!? Automatic transmission dipstick? I think it is bolted on the back of the engine as well on the back passenger side somewhere.
When you lift does the transmission lift as well? Got any separation between the transmission and the engine yet?
Can you see the end of the input shaft on the transmission yet? It may need to come forward a little farther before it will be free from the transmission since you have the 5 speed. It is a little easier on the auto since it doesn't have to come forward as far before it will come up and out.
I got it! Needed to go higher and use a 2x4 for leverage then there was a ground wire below the engine bolted to the cross member... D@$n that was a %&$#@!*//&$#...
I'm glad you got it free! It seems like every time I pull an engine there is always something hiding down behind there someplace that I couldn't see and have to stop to unhook. Now the real work begins!
