fuel screw flats
Old Jul 25, 2012 | 11:08 PM
1989f250IDI's Avatar
1989f250IDI
fuel screw flats
How many flats on the IP does it take to max it out? I know Fordmanmt and 91dirtydiesel has done this. I have myne at 2 flats.
Old Jul 25, 2012 | 11:42 PM
RacinNdrummin's Avatar
RacinNdrummin
That question is not really possible to answer, every pump is tuned by the calibration settings, not by how many "flats" you have your pump turned up... Could be 2, could be 6, just depends how you pump flowed out on the stand...
How about this... Count the flats as you turn it up, and then when it stops, youll know to stop counting... And youll have your answer...
I didnt count the flats, I just turned mine all the way up to begin with...
Old Jul 26, 2012 | 12:07 AM
Aune163rd's Avatar
Aune163rd
Racin....and you wonder how your gonna get another 100k out of this engine???
Old Jul 26, 2012 | 12:37 AM
RacinNdrummin
Na...A maxxed out N/A pump is the least of my worries as far as putting wear on this engine, however, RPM and boost do contribute to the blowby...And even that being the case, I think another 100k is a conservative measure
Old Jul 26, 2012 | 12:43 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Mine bottomed out just past 3, i have heard of 6, but seems the norm is 4-5. I also have to say i agree with racin, my pump maxxed doesnt do nearly what i thought it would.
Old Jul 26, 2012 | 07:57 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
bottom it out and then turn it back out about a flat.
Old Jul 26, 2012 | 04:25 PM
Mikey Oldaker's Avatar
Mikey Oldaker
ya know i had turned one of my previous trucks up prolly about 2.5 flats and it was a 6.9 n/a. man that was interesting least to say. it for a while stopped running then we pull started it and kept it going for a while. needless to say it eventually died but we got it going to the point we could start it and run it by the starter. Well point is it was way too much for this motor or something. dont think it melted anything at all but we true dualed it and put stacks on it. this thing shot two foot flames out of it. and it would barely do 65mph in the end we had to put a new pump on it the fuel screw was rounded out and we couldnt get it back out but we turned it back down to where it was about a 1/4 of a turn up and ran it from there and would still out smoke the high performace chipped piles of **** you see running around town now days with their giant 8 inch since stacks, oversized injectors and enormious turbos. man i was so pissed it got impounded and then crushed i was furious but i couldnt afford to get it out of impound
Old Jul 26, 2012 | 06:10 PM
southtexasidi's Avatar
southtexasidi
mine bottomed out at 4-5 flats
Old Jul 26, 2012 | 09:53 PM
oldblue89's Avatar
oldblue89
^That's the way to do it. I started out with 3 flats, then decided to see what the truck would do with the screw about a flat away from being bottomed out. Even in humid 100 degree weather I never see more than 900 degrees on my ISSPRO pyro - 9psi going up a hill (sender/probe in the cast uppipe of my banks sidewinder system).
Crank it up and roll the coal.
Agnitoood
Jun 9, 2018 09:15 AM
Spktyr
Jan 31, 2016 07:30 PM
bryanlindborg600
Dec 4, 2011 10:30 AM
DAI532
27
Sep 24, 2009 08:34 PM
