The trouble started on the way home from RRE.About a hour from home the trans slipped when in second gear.Then at the next stop light I had to red line the engine to get it to shift into second.then when in second it was slipping a little.After second the trans shifted just fine into drive and OD.Once back on the highway and in OD we didn't stop tell we were home.
Trans is stock and I'm sure the mechanical diode is the problem.
If I was guessing, I'd say it could be the diode. Somebody better at transmissions than I am will have to say more. How many miles on the trans and what kind of towing do you do, or hot rodding (ha). I have a 2001 and the trans went bad before the diode gave up !
Damn Brad, sorry to hear it. and here you were joking that you were going to win the JW because you were so close to Brians. Who knew you were going to need it.
Good Luck My friend.
Damn Brad, sorry to hear it. and here you were joking that you were going to win the JW because you were so close to Brian's. Who knew you were going to need it.
I think Clay snicked over and sabotaged my truck,rigged the drawing just so he could get a JW trans this close to BTS,JK.
