1978 - 1996 Big Bronco
Egr
Old May 10, 2003 | 05:45 PM
David6349's Avatar
David6349
Egr
Does the EGR valve have a solid pipe that goes down to the exhaust manifold/header or is the pipe two pieces?
Old May 10, 2003 | 11:00 PM
steve83's Avatar
steve83
Egr
Well... It's SUPPOSED to be one piece. How many pieces is your?
And what year/engine is your truck?
Old May 11, 2003 | 09:24 AM
David6349's Avatar
David6349
Egr
Sorry its a 1993 351. I had someone put headers on it. They told me it was broken but it looks like it was made this way. Two pices one fits into the other.
Old May 11, 2003 | 10:12 AM
steve83's Avatar
steve83
Egr
I guess it might have been made that way, but I've never seen one like that. Is it leaking anywhere? If so, replace it.
Old May 11, 2003 | 01:22 PM
David6349's Avatar
David6349
Egr
How can I tell if it is leaking? I thnk I am going to unscrew it from the valve itself and look at the pipe. The haynes manual doesn't really show anything. Thanks for your help
Old May 12, 2003 | 08:05 PM
steve83's Avatar
steve83
Egr
Crank the engine and use a 3' piece of garden hose as a stethoscope.
Old May 13, 2003 | 04:36 PM
Big Red Bronco's Avatar
Big Red Bronco
Egr
Hi David, it is supposed to be "one" piece with a threaded pipe in the middle. If it is two pieces. It is broken and needs to be replaced.
And it is expensive from Ford.
Bruce (Big Red Bronco.....almost in the drive for an new new engine)
Old May 14, 2003 | 11:24 AM
brylac's Avatar
brylac
Egr
this is the same problem i have David. local ford dealer has it for $32. problem is after using PB Blaster, it still won't come off. only solution is to take apart the exhaust manifold.
how much longer can i go with this thing busted??
Old May 14, 2003 | 12:49 PM
adelyser's Avatar
adelyser
Egr
It's a single pipe with a flex section in the middle. I removed mine and it was broken too. I just removed it and plugged the ports.
samiott
Feb 9, 2012 08:20 AM
bcfordguy
Apr 1, 2010 09:46 AM
03strokinfl
Sep 24, 2007 09:30 AM
dkrobson
Mar 6, 2006 05:59 AM
steve83
Dec 19, 2002 12:04 PM
